stock dana 35 axle width #743286 08/08/06 05:04 PM
kingfoss Offline OP
i am trying to find the axle width of the rear axle in a 2000 tj. have been lookng but have not found much. also does anyone know if axle shafts for a scout rear end can be redrilled for 5 on 4.5 bolt pattern?
2000 TJ 5" lift
33" BFG AT
Rear 4-link coming soon
Front hp dana 44 and frod 9" Rear coming sonn
Re: stock dana 35 axle width [Re: kingfoss] #743287 08/08/06 05:15 PM
I know the axle widths for my YJ's are mentioned in the chilton....
Don't know if there is enough meat to drill it, you might be able to buy shafts with that pattern.
Re: stock dana 35 axle width [Re: kingfoss] #743288 08/09/06 07:04 AM
TJ, YJ, XJ, and MJ are all 60" WMS to WMS.
Scout is about 58". There should be enough meat there to redrill, but spacers would put you closer to stock width and you wouldn't have to re-drill brake drums if future replacments are ever necessary.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5893 MB (Peak: 0.6434 MB) Data Comp: Off Server Time: 2026-05-29 16:35:17 UTC
