Tire size on a 2002 4Runner?
#74342
07/07/03 03:00 PM
Thanks in advance for helping me out with this. My buddy has a 2002 4Runner, SR5 Limited, 4Wheel drive. He has finally worn out his existing tires, and was wondering how big he could go on replacements. Anybody got any ideas? This is a 99% pavement truck, with occasional very mild off-roading. Thanks!
Re: Tire size on a 2002 4Runner?
#74343
07/07/03 04:30 PM
I would say that if he wants to do some mild off-roading, then to get some all terrain tires. Size wise is up to him. The stock tire size i believe is 265/70/16 and he could probably fit 265/75/16 on there. It is just one size up, and there is no drastic change in power.
#74344
07/08/03 01:34 AM
I installed a set of 275-70-16 instead of 265-70-16 on my 2000 limited. They were $30 cheaper/per set and very easy to find (Michelin LTX M/S 114H). These tires are very quiet, excellent handling at corner or wet road but a it is a bit bouncing if air pressure is below 32 psi due to the higher profile, the only thing that you'll notice right away is the truck seems to be slower of the line. BTW, these tires are exaclty same size with the Land cruiser. Hope this helps. Don
#74345
07/09/03 06:49 PM
As stated above, for stock 4runner, you can go with either 275/70/16 (slightly taller) or 265/75/16 (taller). Anything bigger than these two sizes will cause rubbing.
For street tires (and occas. off-roading), LTX M/S is a good bet. However, don't forget about the all-terrain tires: Bridgestone Dueler AT REVO or BFG AT/KO. Bridgestone REVO is cheaper than BFG and is more street-oriented.
#74346
07/09/03 08:42 PM
I agree. I have the Michelin LTX/MS 265/70/16 right now, but am going to switch to the BFG AT KO's soon. Either lift it and get 285's or just add 265/75/16's on it with no lift.
#74347
07/10/03 03:12 AM
I have 265/75/16's BFG A/T KO's and I love them. I only rub when I turn and hit a bump at the same time. Other than that, no rubbing on a full turn.
PHP: 7.4.33 Page Time: 1.628s Queries: 14 (0.006s) Memory: 0.5972 MB (Peak: 0.6655 MB) Data Comp: Off Server Time: 2026-10-22 16:59:43 UTCValid HTML 5 and Valid CSS
