Pulling to the right under braking #743791 08/10/06 10:26 PM
Davis5210 Offline OP
I have a 1995 toyota 4runner with IFS up front and whenever I brake it pulls fairly hard to the right. I think that it is probably a worn out bushing but I dont know which one.
My runner also has a clicking on the right when turning at full lock to the right especially if I hit a bump.
1995 4runner SR5
PP rear springs
Hella FF1000 lights
31X10.5-15 Nokian Vativas <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Pulling to the right under braking [Re: Davis5210] #743792 08/10/06 10:33 PM
DRTDEVL Offline
Check your idler arm...
If the bushings in it are worn out, the arm can pull downward when braking, allowing the right wheel to turn right. You may also notice a quick side-to-side alternating pull when in 4WD.
Re: Pulling to the right under braking [Re: DRTDEVL] #743793 08/11/06 03:29 AM
Is that the same as the pitman arm, Im not really sure what you rtalking about (sorry newb question)
1995 4runner SR5
PP rear springs
Hella FF1000 lights
Re: Pulling to the right under braking [Re: Davis5210] #743794 08/11/06 03:35 AM
4Crawler Offline
Pitman arm is the short arm on the end of the steering box. The idler arm is on the opposite side of the frame from the steering box:
- http://www.4x4wire.com/toyota/maintenance/idler/
Re: Pulling to the right under braking [Re: Davis5210] #743795 08/11/06 05:52 AM
Snowtoy Offline
A warped rotor will cuase the pull, a stuck left caliper or the right side caliper not fully retracting will also cause it to pull. A normally worn idler arm will allow it to wander, but noit usually pull hard. Worn out lower A-arm bushings will also cause it to wander and clunk on take off and breaking, but not pull like you are experiencing.
I would start with the breaks, pull the wheels and see if the calipers are working properly, check the pads-they should be worn about the same, and spin the right rotor to see if it looks warped. If the breaks look good then look to the idler arm and the rest of the steering linkage.
Re: Pulling to the right under braking [Re: Snowtoy] #743796 08/11/06 06:29 AM
Jake97T Offline
i had the same problem on an 86 4wd...turned out to be the right brake caliper was sticking and it ate the rotor paper thin in a matter of a months.
If your rotors are wearing evenly than ive got a braced idler arm if your interested. $75
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6119 MB (Peak: 0.6818 MB) Data Comp: Off Server Time: 2026-06-19 12:06:15 UTC
