Surging??? 22 re at low throttle #744944 08/15/06 10:53 PM
O
Omega Supreme Offline OP
My truck runs fine on the freeway, but wheni am cruising around in 1,2 or third my truckseems tosurge when my foot is barley on the throttle and starts to buck. Should i clean my injectors or time for anew fuel filter? What do you guys think? It runs fine but this is annoying!! <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Surging??? 22 re at low throttle [Re: Omega Supreme] #744945 08/16/06 01:16 AM
trythis Offline
My guess is your throttle postion sensor is either out of adjustment or needs replacing.
or
your throttle body is filthy and the TPS can't close all the way,
or
It could be that your idle speed is off,
or
if this is with AC, that yuor idle advance compensator thingy is not working or not adjusted right.
or, next person:
Re: Surging??? 22 re at low throttle [Re: Omega Supreme] #744946 08/16/06 02:02 AM
eightyeight Offline
my 4runner does this. pretty sure my tps is out of adjustment (i just put a new one in).
havent adjusted it yet though. i just keep my foot into the throttle <img src="/forums/images/graemlins/evil.gif" alt="" />
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: Surging??? 22 re at low throttle [Re: Omega Supreme] #744947 08/17/06 06:50 PM
G
GeriatricToy Offline
I'd also have to say throttle position sensor. My truck was doing the exact same thing. I tried adjusting it to save a buck but ended up replacing it, and the problem went away for good.
2000 Tacoma SR5 - Bone stock 'cept a little bling.
2000 Tacoma SR5 - Bone stock.
Re: Surging??? 22 re at low throttle [Re: Omega Supreme] #744948 08/18/06 01:04 AM
Kona Offline
I had the same problem a while back and I couldn't figure it out for the life of me TPS was definately good and after liberally coating the engine I didn't seem to have any vacuum leaks. Turns out it was a vacuum leak in the throttle body gasket at the bottom of the TB when the carb cleaner wasn't getting. $2 later and all is well.
Back in the West!
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6034 MB (Peak: 0.6678 MB) Data Comp: Off Server Time: 2026-11-02 21:05:47 UTC
