"Threaded" PCV Valve on Newer 3.5 Engines #745133 08/16/06 05:32 AM
UteTroop Offline OP
On my 2000 Trooper that has a "newer" engine from Isuzu; It seems to have the new "threaded" PCV Valve on it. If I'm looking in the right place...
(Driver's side just above the frontmost cyl.)
I went to local checker auto parts store and bought the Fram FV384 plastic one, but that won't work here will it?
Do these new ones have the same recomended change interval 30-50k miles? Where can I get a replacement for this new metal threaded PCV valve?
Thanks,
-Jared
'00 Trooper S 4x4; OME 912 Coils; LT265/75/R16 Bridgestone Dueller A/T REVO's (Love'EM!)
Re: "Threaded" PCV Valve on Newer 3.5 Engines [Re: UteTroop] #745134 08/16/06 06:03 AM
Richard Saylor Offline
It looks like you'll be looking for Part # PCV193. That's a deutch number. In fram, it should be FV193.
Edit ... ya, it looks like you're probably correct in that that is the PCV valve.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: "Threaded" PCV Valve on Newer 3.5 Engines [Re: UteTroop] #745135 08/16/06 06:22 AM
holger Offline
on my Rodeo 2002, it was exactly like this - a threaded metal valve, in the same place. You probably can use Rodeo 2002 3.2 as a reference vehicle, I suppose it is the same application.
Oleg
Deceased Rodeo'02 4WD.
Re: "Threaded" PCV Valve on Newer 3.5 Engines [Re: Richard Saylor] #745136 08/16/06 11:19 PM
A
Amigo-2k Offline
They will last a long time, but I would get into the habit of spraying it out with carb cleaner everytime you change the oil. A quick 3 minute job.
Re: "Threaded" PCV Valve on Newer 3.5 Engines [Re: Richard Saylor] #745137 08/16/06 11:51 PM
UteTroop Offline OP
I couldn't locate a "193" valve at the auto parts store or on fram's website. I think I did find a match though, I will have to bring in the old one and do a closer comparison to be sure. When I do I will post the number here for future reference.
I did take the old one out to clean and inspect it. Seems to be in good working order but I will probably go ahead and replace it now anyway.
-Jared
PHP: 7.4.33 Page Time: 0.025s Queries: 15 (0.022s) Memory: 0.6067 MB (Peak: 0.6719 MB) Data Comp: Off Server Time: 2026-11-14 22:33:41 UTC
