4.3 manifold leaking coolant #745191 08/16/06 08:14 AM
L
lostone Offline OP
My intake manifold is leaking collant on the outside seal I have seen no evendence that it is getting into the engine itself. My problem is that I am leaving for collage tommorow and my other truck that I was planning to take has computer issues and my not be able to go can I use stop leak to fix this untill I replace the gasket?
Re: 4.3 manifold leaking coolant [Re: lostone] #745192 08/16/06 08:43 AM
52degrees Offline
You can try it, it won't hurt anything.
Unfourunately, it probably won't help at all, either.
KG6VNX
PHP: 7.4.33 Page Time: 1.180s Queries: 15 (0.003s) Memory: 0.5862 MB (Peak: 0.6339 MB) Data Comp: Off Server Time: 2026-06-20 23:55:08 UTC
