Page 3 of 3 1 2 3
Re: MSD Ign Coil for 91 Monty. [Re: fasteddy] #745654 08/23/06 03:35 AM
52degrees Offline
Basically, what we're all saying here is that your money would be better spent on something else. The way the first 3 posts looked by the time I saw them kinda got me started off on the wrong foot, and for that I apologize.
I too have seen many MSD coils fail very early. Factory is best and longest lasting.
If you are having driveability issues only in hot weather, I would definately look elsewhere for the problem. The likelyhood of it being a coil problem is pretty low (but do check the coil output, you can get a cheap coil tester at your local auto parts store to prevent involuntary hair curling/straightening).
KG6VNX
Re: MSD Ign Coil for 91 Monty. [Re: Drewz] #745655 08/23/06 06:19 PM
BobShaw Offline
Be carefull and don't get too hot a coil. I run an MSD coil, large spark plug wires and "truck plugs". The spark plugs do not fowl under heavy fuel flow and don't misfire at low rpm when fording a creek. Yes they are worth the money.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 1.018s Queries: 16 (0.005s) Memory: 0.5947 MB (Peak: 0.6597 MB) Data Comp: Off Server Time: 2026-06-22 11:07:46 UTC
