fuel lines #745996 08/20/06 03:47 PM
Jake Offline OP
Recently finished reassembly of my 22-re(89 runner), after a good long test drive i noticed a strong gas smell. Upon further inspection i found the leak coming from the right frame rail under the passenger door. Thinking i've mixed up some lines to the charcoal canister as they are full of fuel, and the bottom hose disapears into the frame rail right where the leak is.TRying to figure out the location of these lines but my manual doesnt show any fuel line diagrams at all. Any help would be great.
82 4x4- tipped flipped & sunk. A "work in progress"
Re: fuel lines [Re: Jake] #745997 08/20/06 04:47 PM
4Crawler Offline
Probably the cannister is full, not being flushed properly. 3 lines to it, the P line on top goes to the P port on the throttle body (P=Purge). The other line on top goes to the fuel tank vent and the bottom line is just run down to the frame rail to atmosphere:
http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/19.html
The FSM has the testing an cleaning instructions.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5857 MB (Peak: 0.6339 MB) Data Comp: Off Server Time: 2026-06-17 00:12:08 UTC
