Ford 9" #746055 08/20/06 11:33 PM
Tikitgvr Offline OP
Ok so I was cleaning it up some more a few minutes ago and found a weld that might be where it was shortened,
as you can see it is by the housing and it is on both sides. What does it look like to you?
If anyone has one I wanted to see if you would measure it for me from the back of the flange to the other backside flange (arrows are pointing to spots) so I can compare your measurement to the one I am going to get now:
Re: Ford 9" [Re: Tikitgvr] #746056 08/21/06 02:41 AM
tcoff Offline
i'm just curious, what are you going to put it in?
99 wrangler sport, auto. 2.5 inch lift, 31 MTR's
Re: Ford 9" [Re: Tikitgvr] #746057 08/21/06 03:54 AM
I don't know the measurements of that axle, but usually when an axle is shortened they cut the flanges off and weld new ones on.
Re: Ford 9" [Re: Tikitgvr] #746058 08/21/06 04:38 PM
JeePete Offline
It looks to me like that's how a three piece welded case and tubes are put together at the factory. Just an opinion, I don't have one handy to compare to. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Ford 9" [Re: JeePete] #746059 08/21/06 05:09 PM
BigJim Offline
Pete is correct! ALL 9" rears have the factory welds in that location. The center section is forged and the tubes are factory welded on it.. on ALL nineinchers! It looks good to me.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6007 MB (Peak: 0.6610 MB) Data Comp: Off Server Time: 2026-06-13 13:53:21 UTC
