Re: Need help with suspension choice...Badly [Re: Aaron84x4] #746111 08/22/06 03:44 PM
Red_Chili Offline
Toyota Section Staffer
Generally the same people who have used them in the past. Like me, for instance.
-Bill
Re: Need help with suspension choice...Badly [Re: Red_Chili] #746112 08/24/06 10:11 PM
yotaman7 Offline OP
Okay, lets say I run 35 x 12.50. Would a 4" lift look and function right? All-pro front springs move the axle forward 1 1/2". After I beat the seam in the tire well down, I should have enough room, correct?
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: Need help with suspension choice...Badly [Re: yotaman7] #746113 08/24/06 11:28 PM
missouriman Offline
here is my wifes truck, no lift, 34 inch tires. I cut the fenders and the rear of the fender to the cab mount.
she loves the ride, and it don't flex to bad for stock shocks. stock springs, stock steering..
Re: Need help with suspension choice...Badly [Re: missouriman] #746114 08/25/06 03:23 AM
yotaman7 Offline OP
Can someone clear this up for me please. I've noticed that instead of getting taller springs some get longer shackles and a drop front hanger. Why would you want to do this over just getting taller springs. Are flatter springs better for ride quality or flexibilty.
Thanks
'93 pickup 2WD
'85 pickup 4WD
Re: Need help with suspension choice...Badly [Re: yotaman7] #746115 08/25/06 05:01 AM
Brian894X4 Offline
Thanks
The drop hanger design was originally for SASing IFS trucks and you have issues to work around like a lower front IFS frame and steering box that need clearance and a dropped hanger "can" offer better clearance. The other reason is that longer shackles are typically used for better articulation and you need to match the front and rear so that the front diff pinion angle is at least close to stock. And finally, it's easier for a layman to weld on a single front hanger, so they were designed to be beefy and one piece and that made some lower the hanger a bit.
Everyone is offering great advise here. Definately stay away from a bodylift/spring lift combination. Maybe one or the other.
I ran my SAS with 35s with 4" of lift and cut fenders and more room than I ever needed. Probably could have cleared 37s. Moving the axle forward a bit is an important factor.
Whatever you do, you don't want too much lift. And since you're lucky enough to have an '85 with the high arch frame, take advantage of it and run as low lift as you can for more trail stability. Unfortunately, SAS trucks like mine pretty much can't go any lower than about 4" of suspension lift, because of the frame.
If you're gonna run 33s, I like the idea of trying to keep the lift close to 2-3". If 35s, absolutely no more than 4" is needed as I've proven.
Re: Need help with suspension choice...Badly [Re: yotaman7] #746116 08/25/06 06:54 AM
4Crawler Offline
Thanks
All things being equal, a long flat spring will flex more than a highly arched spring. The more arch a spring has the stiffer it is. My front springs only give me about an inch of lift, if that. The rest (3") comes from the lowered front hanger and longer shackles:
http://www.4crawler.com/4x4/4R_suspension-III.shtml#Update-part3
Re: Need help with suspension choice...Badly [Re: yotaman7] #746117 08/26/06 01:45 AM
subliminaltrips Offline
try trail gear, great price and the parts are quality, i know a guy with this kit and 63'' chevy springs in the rear, he goes everwhere with his 36x13.50 iroks
http://www.trail-gear.com/classic.html
i like this kit because it includes the hub kit and the knuckle rebuild kit. just add an ifs box and your good.
Re: Need help with suspension choice...Badly [Re: subliminaltrips] #746118 08/26/06 02:29 AM
87Toy4x4 Offline
NO lift.....37" tires.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6350 MB (Peak: 0.7356 MB) Data Comp: Off Server Time: 2026-11-16 01:17:09 UTC
