Affordable O2 Sensors that are plug N play #746305 08/21/06 10:08 PM
02' Dblcab 4x4 taco 3.4 only 34K miles, K&N cold air & Gibson Cat back - Due to crappy gas mileage and sluggish acceleration I recently cleaned the MAF & Throttlebody, changed the fuelfilter, used 1/3rd can of seafoam on the top end and the rest in the gas tank. It's better but not back to what it should be. I'm thinking O2 sensors would help. Had a check engine for about 3 days 10K miles ago and about 5K after the filter & cat back install but never read the code. I've priced O2 sensors from $365(Bosch at Advance Auto) to $26(Denso on ebay, would need to solder the plug on). My question is whats the most affordable O3 that comes with the plug already attached?
Re: Affordable O2 Sensors that are plug N play #746306 08/21/06 11:27 PM
bard Offline
  • Search for 'Denso'
  • Get your code read
Re: Affordable O2 Sensors that are plug N play #746307 08/22/06 12:32 AM
stock87 Offline
http://www.sparkplugs.com/
OEM supplier, without the OEM prices.
Or
http://www.oxygensensors.com/
Go for NGK or Denso, stay away from Bosch and others.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Affordable O2 Sensors that are plug N play [Re: stock87] #746308 08/30/06 03:19 PM
Check out http://www.urdusa.com/
They have the original Denso stock replacements for just under $100.
I think its their owner who goes by "Gadget" on the TTORA forums, if you wanna find out about the place before buying anything...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5921 MB (Peak: 0.6510 MB) Data Comp: Off Server Time: 2026-10-24 12:44:51 UTC
