Re: how do you torque a crank pulley bolt? [Re: Tag] #746383 08/22/06 03:36 AM
Mad_Scientist Offline
Maybe my pulley looks more like yours. Do you have any pics? Maybe mine has been switched out with a newer one by the previous owner.
I don't have a pic, but I could take one of the pulley and the tool in the morning when it's daylight. How do I upload the pic?
I think a belt wrapped around the pulley would be a struggle if 134lb/ft is required. I though it was tough and the tool I made is 3.5 to 4 feet long <img src="/forums/images/graemlins/kewl.gif" alt="" /> Anyone is welcome to borrow it. It's very rough, but it works <img src="/forums/images/graemlins/notooth.gif" alt="" /> I could make a prettier one but at the time I was more interested in getting the marathon 'timing belt and everything that goes with it' job done.
Re: how do you torque a crank pulley bolt? [Re: Mad_Scientist] #746384 08/22/06 03:50 AM
52degrees Offline
KG6VNX
Re: how do you torque a crank pulley bolt? [Re: sparkem] #746385 08/22/06 04:28 AM
StockRaider Offline OP
I just got done. I wrapped tiedown straps around the crank pully and anchored them down to the tow hooks and started tightening, the more I turned the tighter it got till at 134lbs the wrench went click and I was done! <img src="/forums/images/graemlins/kewl.gif" alt="" /> I started it up and I did notice the engine was making the valve tic noise for 20 seconds longer than the usual 5... It went away so ohwell <img src="/forums/images/graemlins/ignore.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: how do you torque a crank pulley bolt? [Re: StockRaider] #746386 08/22/06 04:49 AM
FrankR Offline
Tie-down straps? <img src="/forums/images/graemlins/scared.gif" alt="" /> Damned fine ingenuity and a new method! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: how do you torque a crank pulley bolt? [Re: FrankR] #746387 08/22/06 07:01 AM
I work with what I can to make it work <img src="/forums/images/graemlins/notooth.gif" alt="" />
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6152 MB (Peak: 0.6805 MB) Data Comp: Off Server Time: 2026-06-24 13:48:44 UTC
