Carb to EFI? #746489 08/22/06 12:45 PM
Kotrin Offline OP
I have an 84 Toyota pickup and was wondering how difficult it would be to switch it to the EFI setup. I believe i'll need another computer or a different one but from what i've looked at it, it doesn't look too terribly difficult(I know looks are decieving, heh). I figure that this may help the problem's of having to stop/start on a steep hill and may keep me from getting a diff carb. Thanks
http://home.4x4wire.com/caz/tech/22REconv.htm
I think this may explain what i'm looking for will have to look more, but if anyone has any other advice I would appercaite it smile
Hmm, sounds to be easier to just find a complete EFI engine..lol.
- Kotrin
Re: Carb to EFI? [Re: Kotrin] #746490 08/22/06 05:50 PM
V
Volcom Offline
I'm right in the middle of that process now. I have an 84 4Runner that I'm swapping in all the EFI stuff from an 85 4Runner. So far I've swapped, fuel tanks, fuel lines, complete engine and dash wiring harnesses, and am using a rebuilt block and all the EFI components.
http://www.rockfrogs.org/phpBB2/viewtopic.php?t=110&start=0
It's alot of work and I'm still not done <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: Carb to EFI? [Re: Volcom] #746491 08/22/06 08:49 PM
DirtyHarry Offline
Toyota Moderator
Mike Fox has good info on his website too.
http://www.yankeetoys.org/black900rr/EFI.html
Re: Carb to EFI? [Re: Kotrin] #746492 08/23/06 02:54 AM
kewlynx Offline
So you got that thing then?
One F/S down in the F/S section, Austin. <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
Re: Carb to EFI? [Re: Kotrin] #746493 08/23/06 06:37 AM
Davepet Offline
I'm also in the middle of a swap. I'm putting 87 4runner parts into my 84 xcab.I'd advise getting a complete donor truck. There are differences on some 22R's that are supposed to make it difficult to bolt up 22RE manifolds. I'm installing a rebuilt 22RE block & the EFI parts off the 87, so I'm not up on the differences.
Take lots pictures of the disassembly...saves a lot of second guessing as it goes back together (take lots more than you think you'll need, invariably the one part you want to check out is hidden by an otherwise perfect camera angle).
I haven't tackled the wireing yet, looks like it'll be a head scratcher, pretty much just like that article says.
It can be done, but it's no weekend project.
Dave
Re: Carb to EFI? [Re: Davepet] #746494 08/23/06 07:04 AM
52degrees Offline
Lemme know how the smog crapola goes. I wanna know.
You anywhere near Motown?
KG6VNX
Re: Carb to EFI? [Re: 52degrees] #746495 08/23/06 07:41 AM
Davepet Offline
Yeah, that will be the last step of this interesting project, & I shouldn't have to do that until 6-08. I understand it'll require a trip to a referee to verify that I put in *all* the 87 smog equipment properly.
?? If you mean SF, not really, I'm up in the mountains about halfway between Sacto & Reno.
Dave
Re: Carb to EFI? [Re: Davepet] #746496 08/23/06 08:52 AM
52degrees Offline
Motown=Modesto. You'd only know that if you were from the 209...
KG6VNX
Re: Carb to EFI? [Re: 52degrees] #746497 08/23/06 12:55 PM
Kotrin Offline OP
The truck I got was orginally from Cali with the smog, but I'm not required to run it in Oregon so I was just going to yank that off. The more I read about it think's I may wait till after I get everything else done before I go attempting it. Not that I do not want to do it, just would like to beable to wheel it this winter not having it in pieces =)
So instead of efi'ing it I think i'll put the money into lockers/regearing it. Should I regear, then lockers or do it both at the same time?
- Kotrin
Re: Carb to EFI? [Re: 52degrees] #746498 08/24/06 06:06 AM
Davepet Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> & here I thought we were just being politically incorrect <img src="/forums/images/graemlins/wink.gif" alt="" />
PHP: 7.4.33 Page Time: 5.094s Queries: 16 (0.004s) Memory: 0.6377 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-06-20 13:44:46 UTC
