Warped exhaust manifold (360)
#746831
08/23/06 11:31 PM
I did a search and couldn't find anything on this. But, are there any easy fixes for this problem? That is short of having it resurfaced, i.e. two gaskets.. super glue <img src="/forums/images/graemlins/confused.gif" alt="" /> whatever? This leak is driving me crazy. Thanks
Re: Warped exhaust manifold (360)
#746832
08/24/06 01:00 AM
I guess it is possible but I have never had a cast exhaust manifold warp. Make sure it is torqued to a NEW gasket real good. If you do get it out straight edge it to make sure it IS warped. And NO! 2 gaskets will only leak quicker. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
#746833
08/24/06 01:08 AM
No easy fix. Re-surface or replace.
[Re: BigJim]
#746834
08/24/06 01:12 AM
Yep, it had new gaskets. It's out and the straight edge shows its uneven when laying across all exhaust ports. Haven't checked the head but I will next. Not that that will do me any good. Thanks, Gary
#746835
08/24/06 01:53 AM
No easy fix. Re-surface or replace. Gonna take it to a machine shop tomorrow. Sounds like two is a no-no also. I even had 3 tubes of super glue all ready too <img src="/forums/images/graemlins/frown.gif" alt="" /> Thanks, Gary
[Re: get2now]
#746836
08/24/06 04:21 AM
Don't put ANYTHING on an exhaust gasket!!! Just clean both surfaces real good and install it. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#746837
08/24/06 06:43 AM
Don't put ANYTHING on an exhaust gasket!!! Just clean both surfaces real good and install it. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />I was just kidding abou the super glue <img src="/forums/images/graemlins/lol.gif" alt="" />
#746838
08/24/06 04:06 PM
That was real funny! One must remember everyone here does not know what they are doing and might take funny stuff as truth. I, however, do see the lighter side of your remarks. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
[Re: BigJim]
#746839
08/25/06 05:54 PM
Okay, here's the sad part... when I took off the manifold I put a straight edge on it and it appeared warped. Then I put a straight edge on the head and it appeared warped too. Too much of a coincidence for both to be warped so I re-read the above posts and discovered I should clean the surfaces first, then put the straight edge on. Well, after I cleaned them real good they were magically transformed to perfect. Who da thunk it <img src="/forums/images/graemlins/notooth.gif" alt="" />!!!! I still wanted to know why this happened so I started looking closely and found that what I had done was put the gaskets on backwards <img src="/forums/images/graemlins/scared.gif" alt="" />. They were metal with holes on one side and gasket on the other. I had mistakenly put the metal side out so it was against the manifold so it wasn't able to get a good seal. That in turn blew the gasket material off the metal surface. Thanks to all who helped. Now if I can just fix that clunking sound.<img src="/forums/images/graemlins/confused.gif" alt="" /> That's next.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6184 MB (Peak: 0.7041 MB) Data Comp: Off Server Time: 2026-05-29 15:28:34 UTCValid HTML 5 and Valid CSS
