Re: Changing ATF
[Re: Angelo]
#746871
09/17/06 08:24 PM
Hello everyone, new to the forum. Because I've never owned an A/T'd vehicle, out of stupidity I drained the ATF when I was trying to do an oil change.
All I need is to fill back up the spec level, I don't need a flush. Has anyone pumped fluid in from the dipstick input? Sounds grotesque, I know, but for my purposes I don't see why it wouldn't work. I want to double check though since stupidity got me here in the first place.
Re: Changing ATF
#746872
09/17/06 08:30 PM
2nd post to get sig info to show up.
2000 Montero Sport, 3.0L <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Changing ATF
#746873
09/17/06 08:40 PM
Has anyone pumped fluid in from the dipstick input? Sounds grotesque, I know, but for my purposes I don't see why it wouldn't work. I want to double check though since stupidity got me here in the first place. I beleive that's the only way to do it. Don't worry I've got worse mistakes when it comes to Automatics. <img src="/forums/images/graemlins/ignore.gif" alt="" />
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
Re: Changing ATF
[Re: 87Montero]
#746874
09/17/06 10:04 PM
I'll check with the dealer in the AM, but for now, that's gonna be the plan unless I hear otherwise <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Changing ATF
#746875
09/17/06 10:08 PM
I'll check with the dealer in the AM, but for now, that's gonna be the plan unless I hear otherwise <img src="/forums/images/graemlins/cyclops.gif" alt="" /> Not really. ATF is pretty thin, just get a long and skinny funnel, it goes down easy. I think the pan only holds something like 3 quarts?? Make sure you're using Mitsu Fluid in there. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Changing ATF
[Re: 87Montero]
#746876
09/17/06 10:11 PM
Like he said, fill through the dipstick hole.
Re: Changing ATF
[Re: sparkem]
#746877
09/17/06 10:34 PM
Sweet, then that's the plan.
Re: Changing ATF
[Re: sparkem]
#746878
09/18/06 04:25 PM
I have never changed my own tranny fluid, but you fill'er up at the dip stick that leads to the tranny, correct?
Macka, did you ever get any info on that lil pump you made to pump everything out. Inquiring minds want to know. Angelo
Re: Changing ATF
[Re: Angelo]
#746879
09/18/06 05:03 PM
I have never changed my own tranny fluid, but you fill'er up at the dip stick that leads to the tranny, correct? Angelo, short answer yes. Long answer... see 5 of the 6 posts above yours. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Changing ATF
[Re: off-roader]
#746880
09/19/06 03:48 PM
Draining the pan then filling it up thru the dip stick tube will not change all the tranny fluid. I have mine back flushed at a quick oil change place.
