Re: Changing ATF
[Re: Macka]
#746881
09/19/06 04:07 PM
Hey Macka, havent heard from ya in awhile. I was at PepBoys the other day and saw that drill pump you were talkin about. How did you make that adapter to fit and be used for your tranny lines. Which one is in and which one is out. I've seen it done on a machine before, but cant remember which one is which. Still learning, sorry. Any more info you can provide would be great. Angelo
Re: Changing ATF
[Re: Angelo]
#746882
09/19/06 06:59 PM
I usually buy a 9 quarts of ATF. I drain what I can out of the drain plug. I fill up back up to previous level about 3 quarts. I drive around for a few miles. Drain and fill, drive around. The drain and fill one last time. The 3rd time draining the fluid, it looks clean. 9 quarts or even 12 if you want to do it 4 times, is a lot cheaper than $99-$139 at the local lube place. I need to do in on my SR sometime soon.
Re: Changing ATF
[Re: sparkem]
#746883
09/19/06 08:02 PM
SParkem I remember draining some strawberry milkshake out of your trans one time. When we rode that creek way wa up into nowhere with my club <img src="/forums/images/graemlins/kewl.gif" alt="" /> You have any pictures from that trip?
Re: Changing ATF
[Re: LandRaider]
#746884
09/19/06 08:46 PM
Yes, I have lots. I will post some, I might start an old mitsu pics thread. I am actually in the process of getting a bunch of old pics off of my old comp I lost the power cord. I just bought a cord from ebay and it came in the other day.
I dont have pics of changing the fluid though. Fun trip.
