2.6L into my 87 trooper #747711 08/27/06 05:21 PM
Anybody have info on swapping a 2.6L with fuel injection (from a 89?) into my 87 Trooper II? Any tips will be much appreciated! It has a 5 speed trans and a worn out engine (bad head & trashed carb). I don't want to spend any more $ on this engine. I have a 4.3L from a Chevy S15 but don't want to deal with that swap. I think the 2.6L will be much cleaner and dependable.
Re: 2.6L into my 87 trooper #747712 08/27/06 07:43 PM
Richard Saylor Offline
It'll work and probably be the simplest of swaps (other than the exact replacement). Basically all you'd need is the 4ZE1 engine, fuel injection, wiring harness, fuel lines, and fuel tank from the donor vehicle.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 2.6L into my 87 trooper [Re: Richard Saylor] #747713 08/27/06 09:13 PM
Troopersphere Offline
and by "fuel injection" I'm sure Richard is including the ECM in that package! I think the hardest part will be replacing the wiring harness.
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: 2.6L into my 87 trooper #747714 08/28/06 09:19 PM
coldrain Offline
If the change over to fuel injection is a problem, the 87 intake and exhaust manifolds from the 4ZD1 will bolt up to the 4ZE1.
PHP: 7.4.33 Page Time: 1.220s Queries: 15 (0.008s) Memory: 0.5966 MB (Peak: 0.6554 MB) Data Comp: Off Server Time: 2026-11-19 00:13:07 UTC
