Page 5 of 7 1 2 3 4 5 6 7
Re: SAS conversion pics [Re: LandRaider] #748390 11/23/07 05:50 PM
Why narrow them? I understand they need some attention but given you do the work yourself, I see it as being reasonably priced.
Did you narrow your D44? And can I get 4.634 gears for a D44? <img src="/forums/images/graemlins/wink.gif" alt="" /> I have been reading everything I can get my hands on about the SAS. I have a company car now so it might be time to set the Montero up for serious trails.
Re: SAS conversion pics [Re: cmonty72] #748391 11/24/07 12:54 AM
LandRaider Offline
No I did not need to narrow it because I picked it out of a vehicle that already had the diff on the correct side, and correct width in a STOCK CONFIGURATION.
And no you can't get 4.636, but you can get 4.56 which is close enough to work great. <img src="/forums/images/graemlins/wink.gif" alt="" /> thats what I run.
You can get D44's out of tons of vehicles. You have to pick the right one. IF you are going to go D60, it is unlikely that you will be able to find one in the correct width for as small a truck as a gen1, or 2. MOST 60's came in 1 ton rigs. 3500's F350's and the like. POSSIBLY you can find one in something like a push cart at an aitport or something.
Narrowing an axle set would toss in at least $1000 each. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: SAS conversion pics [Re: LandRaider] #748392 11/24/07 02:20 AM
FatTony Offline
How much wider is a full width axle than a 1'st gen? I don't have one arround here to measure. I can get full width axles a lot easier than narrow ones, but I don't want to have to cut my bath tub in half to make flares. I'm having trouble finding a waggy axle arround here. Yotas are easier to find but full width everywhere.
88 Raider sas, doubler, boggers
Re: SAS conversion pics [Re: FatTony] #748393 11/24/07 04:17 AM
LandRaider Offline
Alot.
You will be doing this.
"I'm having trouble finding a waggy axle arround here. Yotas are easier to find but full width everywhere.
Full width is crazy wide. If you do full width, plan on 44 inch tires or larger, and massive lift to make it look right.
Re: SAS conversion pics [Re: LandRaider] #748394 11/24/07 02:10 PM
Chris_J Offline
Yes. But 5.29s are available for a D44 as well as the Mitsu rear end. Talked to a buddy of mine and I can get a 4.3 for super cheap as well as the tranny and t-case so I may be going that route this summer. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: SAS conversion pics [Re: Chris_J] #748395 11/24/07 09:20 PM
L
Lee N Offline
Are you sure about 5.29's? Reider Racing lists only 5.13 or 5.38 for a D44. When I looked at it before, only a Ford 9" (which would be custom for a front end) had 5.29's available.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: SAS conversion pics [Re: Lee N] #748396 11/25/07 06:55 AM
Brianawd Offline
Looks like I get lucky. I just found a Dana44 HP with 4.27s and its the later Dana 44 so it has the 30 spline axles with disc brakes and warn hubs. Hoping to pick it up next week <img src="/forums/images/graemlins/smile.gif" alt="" />
92 Galant vr4 11.17at132mph
98 Montero 2.5"lift,33/10.50/15,15x8procomp wheels.
trail-gear rock sliders,ARB front bumper,Warn m8000 winch. Piaa lights.
Re: SAS conversion pics [Re: Brianawd] #748397 11/25/07 07:40 AM
LandRaider Offline
How wide, and what side differential?
Re: SAS conversion pics [Re: LandRaider] #748398 11/25/07 08:07 AM
Brianawd Offline
Well its off a 76 bronco so its around 58" and it will be a drivers side drop just like yours. If I do end up picking this up I still don't know if I am going to put it in my gen2.5. Just as of today I have started my search for a 2door Montero/Raider. I found one I need to go and look at for $350 shot engine.
Re: SAS conversion pics [Re: Brianawd] #748399 11/25/07 06:09 PM
LandRaider Offline
Sounds like that will work great. IF it is 5 lug, you can put wagoneer knuckles on it to get an easy 6 lug conversion. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6509 MB (Peak: 0.7567 MB) Data Comp: Off Server Time: 2026-06-07 07:24:29 UTC
