Tilt Column Swap. #748517 08/30/06 12:45 AM
tucker80 Offline OP
I have a 90 pickup and want to swap in a tilt column. I found some old posts that said it is pretty straight forward. The column is from a 4runner, I'm pretty sure they are the same, but if anyone knows otherwise please jump in.
Thanks,
Matthew
'90 Pickup 22RE 4.30's, 31 STT's, MossyRock Sliders
'90 2wd xtraCab, getting a heart transplant
'88 4Runner with a thrown rod, waiting in the wings
Re: Tilt Column Swap. [Re: tucker80] #748518 08/30/06 01:30 AM
kewlynx Offline
I believe if you get them from the same generation vehicle where the fitment is good with the dash area, you'll be good to go. 4 bolts and your harnesses, basically. You'll need a paperclip to undo the key cylinder if wanting to keep the same stuff.
**ubi apis- ibi salus**
Re: Tilt Column Swap. [Re: kewlynx] #748519 08/30/06 03:40 AM
tucker80 Offline OP
Thanks for the info. The column is from an early 90's runner. and thanks for the tip on swapping out the key cylinder.
Matt
Re: Tilt Column Swap. [Re: tucker80] #748520 08/30/06 10:50 AM
kewlynx Offline
Yer welcome. We have an fsm sticky'd in the early trucks section if you need it.
BTW, if you didnt' have delayed wipers before and this new column has them, you'll need the wiper relay behind/above the ECU on the pax side as well.
Just checkin' <img src="/forums/images/graemlins/notooth.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6030 MB (Peak: 0.6585 MB) Data Comp: Off Server Time: 2026-06-18 21:32:42 UTC
