Re: Lo-Med-Hi Blower Switch [Re: Stevie] #748553 09/06/06 10:39 PM
4Crawler Offline
If blower motor works on any speed, then it is fine. All the resistros do is limit current to the motor by dropping the voltage across it. They are placed in series with the motor by the switch. The factory resistor pack is obvious if it is burned out, a good one will have wires coils coated in ceramic insulation:
A blown one will have burnt off stubs of wire sticking out where the coil used to be.
http://www.4crawler.com/4x4/CheapTricks/Blower.shtml#BlowerResistor
If the switch is OK and the resistors are OK, then the only thing left, sped-related, is the wires between the switch and the resistor. The switch masically shorts out parts of the resistor pack to increase the speed. Low speed is all the resistor segments, medium has the first part bypassed and high speed has them all bypassed. So if low and med. are missing, something is keeping those resistor segments either shorted out ot the wiring has been changed to just be to the high side of the resistor all the time.
Re: Lo-Med-Hi Blower Switch [Re: 4Crawler] #748554 09/07/06 02:22 AM
Stevie Offline OP
Right on. I'll check those wires out, and probably breakdown & buy the real replacement. <img src="/forums/images/graemlins/wink.gif" alt="" />
'80 4X4 Longbed
Re: Lo-Med-Hi Blower Switch [Re: Stevie] #748555 09/10/06 11:08 PM
I
irsean Offline
Yup Hi-Low fan is definately the toyota resistor pack. Had the same problem.
Re: Lo-Med-Hi Blower Switch [Re: irsean] #748556 09/11/06 01:37 AM
4xJedi Offline
Just go to Autozone and buy the real resistor for $18.00,
Blower Motor Resistor
and be done with it <img src="/forums/images/graemlins/smile.gif" alt="" />.
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
'00 F250 PowerStroke
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6090 MB (Peak: 0.6655 MB) Data Comp: Off Server Time: 2026-06-10 01:22:24 UTC
