Electronic control module questions #748631 08/30/06 04:22 AM
G
Greg2000 Offline OP
What is the easiest way to tell if your ECM has gone bad? And were can you find one? The jeep in question is an 85 cj7 with the carter bbd carb.
Re: Electronic control module questions [Re: Greg2000] #748632 08/30/06 04:43 AM
JeePete Offline
Bypass it. The Ignition bypass <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Electronic control module questions [Re: JeePete] #748633 08/30/06 04:45 AM
G
Greg2000 Offline OP
I would like to but according to colorado state emission laws the original emissions controls need to be intact for it to be licensed
Re: Electronic control module questions [Re: Greg2000] #748634 08/30/06 05:25 AM
You test it by the process of elimination. Have you verified that the coil and the wire/cap/rotor are good?
Re: Electronic control module questions [Re: Greg2000] #748635 08/30/06 05:32 AM
JeePete Offline
Of course I meant for diagnostic purposes only! I might have one you can have.
Re: Electronic control module questions #748636 08/31/06 12:48 AM
G
Greg2000 Offline OP
Sunder,
verified that all is working including the stepper motor and the ECM. But when I check the O2 sensor voltage it is reading rich. The carb. will not lean itself out as it should. The voltage I am getting is almost a volt .945. It is my understanding if all is working well it should read less than a half volt. The vehicle but all other standards is running great.
Re: Electronic control module questions [Re: Greg2000] #748637 08/31/06 01:03 AM
So when the key turns on the stepper motor goes all the way one way then the other then stops somewhere in the middle?
Re: Electronic control module questions #748638 08/31/06 08:15 PM
G
Greg2000 Offline OP
Sunder,
When the vehicle is running the stepper motor is or pin is moving back and forth contantly trying to make corrections to the rich problem. I have checked all the other important stuff temperture switch and what not through the diagnostic port next to the battery. It indicates all is working well. I have also moved the metering rods both to full rich and full lean no difference. Could the carb just need rebuilt.
Re: Electronic control module questions [Re: Greg2000] #748639 08/31/06 10:23 PM
BigJim Offline
Greg I would think the stepper motor would be PEGGED in the lean position if the computer was telling it the mixture was too lean.
Re: Electronic control module questions [Re: BigJim] #748640 08/31/06 10:27 PM
G
Greg2000 Offline OP
BigJim,
I would think so as well but it is not it is hunting around for the optimal sitution but cannot find it so it runs rich. Would rebuild the carb help this sitution.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6319 MB (Peak: 0.7342 MB) Data Comp: Off Server Time: 2026-07-14 21:52:13 UTC
