por-15 ?
#749256
09/03/06 12:47 AM
how much of this do you guys think I would need to coat my frame?
1986 xtra-cab 22re stock everything 1991 bed
Re: por-15 ?
#749258
09/03/06 01:56 AM
I used about 3 pints out of the gallon I purchaced . inside and out . ![[Linked Image]](http://www.toyotafiberglass.com/images/IM000826.JPG)
Re: por-15 ?
[Re: CJM]
#749259
09/03/06 04:55 AM
Thanks for the info, and that is one pretty frame!
Re: por-15 ?
[Re: CJM]
#749260
09/03/06 03:08 PM
I used about 3 pints out of the gallon I purchaced . inside and out . I think I went through a gallon when I did my frame back in 96 - two coats. But... There are better products out there. I've spent about $300 on POR-15 over the years and never once been happy.
Brian K. Gallus I have nothing important to say.
Re: por-15 ?
[Re: bkg]
#749261
09/03/06 06:51 PM
But...
Hmm. Any suggestions as to what they might be? I've used three different products and so far, POR-15 is the best - though I have admittedly been let down occasionally. Please share.
85 Toy Pickup 89 block 30 over and EB RV head/261 cam
Re: por-15 ?
[Re: ToyotaT]
#749262
09/03/06 07:14 PM
I've heard good things about some products from Eastwood. But I think the truth of the matter is that this is an attempt at a shortcut to eliminate rust - And the best solution is to not take the short cut. Just my opinion.
Re: por-15 ?
[Re: bkg]
#749263
09/03/06 10:43 PM
ive used the estwood rust encapsulater,por 15 rip off, and after having the frame sand blasted i brushed on the coating thinned a little with thinner and now it has seaped in so well that whenever i need to grind some paint off the frame it actually clogs the wheel a bit. i used multiple coats though. excellent product.
Re: por-15 ?
[Re: jaguarshark]
#749264
09/04/06 04:00 PM
I just got done painting the frame with a product called chassis saver which is very similar to POR-15. It took me about a half a gallon for 2 coats. My frame is an '85 short bed/reg cab. We'll see if this stuff works or not. Oh yeah, do not shake the can once you've opened it. Trust me <img src="/forums/images/graemlins/lol.gif" alt="" /> ![[Linked Image]](http://i20.photobucket.com/albums/b233/TACTOY/frame002.jpg)
Re: por-15 ?
[Re: CJM]
#749265
09/05/06 06:24 AM
I used about 3 pints out of the gallon I purchaced . inside and out . how did you get inside the frame?
93 ext cab. 3.4 in progress
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6270 MB (Peak: 0.7344 MB) Data Comp: Off Server Time: 2026-06-23 00:10:10 UTCValid HTML 5 and Valid CSS
