22rec intake manifold removal #749723 09/05/06 10:20 PM
Mikeweb Offline OP
I am having trouble getting the intake manifold off of my 1986 4runner 22rec engine. I pulled 7 bolts and 2 nuts, and it won't budge. Am I missing something? There is an allen bolt sort of below and near where the thermostat housing is, and I can't seem to get to it to get it off. Is that what is holding the manifold on? Any help would be greatly appreciated.
Re: 22rec intake manifold removal [Re: Mikeweb] #749724 09/05/06 10:26 PM
4Crawler Offline
Yep, that allen bolt has to come out, 6mm socket as I recall.
Re: 22rec intake manifold removal [Re: 4Crawler] #749725 09/05/06 10:29 PM
Mikeweb Offline OP
Thanks, it came right off. Anyone else working on this, I recommend a ratchet mount 6mm allen wrench w/ about a 10" extension in order to be able to get to the bolt. Without that it is pretty tough to reach.
Re: 22rec intake manifold removal [Re: Mikeweb] #749726 09/06/06 07:46 AM
Davepet Offline
Mine was hopelessly stripped out. I ended up removing the fuel rail & using vise grips on it. I didn't waste time trying to find an aftermarket replacement, I just paid the dealer a few bucks for a new one.
Dave
Re: 22rec intake manifold removal [Re: Davepet] #749727 09/06/06 08:12 AM
toyrunner Offline
Dave
x2 <img src="/forums/images/graemlins/notooth.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
Re: 22rec intake manifold removal [Re: toyrunner] #749728 09/07/06 05:25 AM
MisterZee Offline
yep if someones been there before ya, chances are good its wallowed out. also, the bolt is exposed to coolant I think, and it gets rusty and grungy.
98 Taco 4WD
Re: 22rec intake manifold removal [Re: MisterZee] #749729 09/07/06 04:17 PM
drainsbe Offline
Actually I beleive it's a T-40 torx head... worked great for me. No slip/No strip <img src="/forums/images/graemlins/shiner.gif" alt="" />
Dave
86 4Runner, 22R-EB
Re: 22rec intake manifold removal [Re: drainsbe] #749730 09/07/06 05:08 PM
RatLabGuy Offline
I have been very curious about this bolt ever since I had to take it out myself, and every time I read somebody else w/ the same problem.
Any ideas on why in the world this thing is designed like this, w/ the allen bolt sunk in there? Why not just a regular hole and 12-14mm bolt like everything else?
It's not like Toyota to do stuff randomly by any means, just looking for ideas on what the logic could be.
Question Reality.
Re: 22rec intake manifold removal [Re: drainsbe] #749731 09/07/06 05:40 PM
toyrunner Offline
Stock is a 6mm cap bolt
A Torx would be way better, less chance of stripping.
Danny
1985 SR5 4Runner
4.7:1 single case
Re: 22rec intake manifold removal [Re: RatLabGuy] #749732 09/08/06 05:22 AM
Davepet Offline
The allen head bolt is used so the manifold can be removed with the fuel rail & injectors attached. It would be impossible to do that with a standard bolt.
& yes, stock is 6mm allen, I just bought one from the dealer.
Dave
PHP: 7.4.33 Page Time: 7.065s Queries: 16 (0.004s) Memory: 0.6377 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-06-14 15:22:30 UTC
