____C a r b u r e t o r s ___? ? ? ! ! ! #749819 09/06/06 04:27 AM
bayrunner Offline OP
Hey Guys___ Just curios if any of you Toyota (22r engine) guys are running Webber carburetors or just stock. Also what your experience (good or bad), with either carb.and what you recommend and why. You know things like ease of adjustments, rebuiltabilaty, running well, economy etc. Thanks in advance______ BAYRUNNER
Re: ____C a r b u r e t o r s ___? ? ? ! ! ! [Re: bayrunner] #749820 09/06/06 04:45 AM
SALMONHEAD Offline
I run the weber 38 with hedman header & msd ignition. The setup is simple to tune,jet and trouble free. However, the truck was set up that way when I bought it so all I had to do was tune & jet the weber (once I got it setup, I haven't had to touch it). I get 17mpg winter, 18 mpg summer and 16 mpg offroad, very consistently. For 99% of 4 wheeling I prefer gears over horsepower, so if I was spending the money I'd take gears and a locker over engine mod's anyday. Not to mention, keeping it smog legal which increases your available market area if you ever sell it. Just my 2c.
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: ____C a r b u r e t o r s ___? ? ? ! ! ! [Re: SALMONHEAD] #749821 09/06/06 06:21 AM
Scerb Offline
I haven't installed a weber personally, but I own one and know if you search you will find a lot of info. I searched and it eventually convinced me to make the purchase - i got a good condition used one for cheap.
-Scerb
Re: ____C a r b u r e t o r s ___? ? ? ! ! ! [Re: Scerb] #749822 09/06/06 01:54 PM
subliminaltrips Offline
im running a weber 38 on my 84 it runs great, the only problem i had was with the throtle linkage because my factory return sping wouldnt quite return it to the throttle stop. i have a spring on it now but im going to go to a yard and get some linkage that isnt bent to hell. as for the carb i bought, it works great right out of the box. i simply set the idle and drove off.
Re: ____C a r b u r e t o r s ___? ? ? ! ! ! [Re: SALMONHEAD] #749823 09/06/06 08:46 PM
Aaron84x4 Offline
I'm running the webber 38 street lethal with LCE header, Jacobs ignition system, and i even got the jet kit for the carb. Right now its running stock jetting, but i havn't played with them yet since i opened up the exhaust with the header and 2.25" exhaust + flowmaster. Havn't had any problems smogging.
I like the setup, it has been working well, and once i change the float level it won't load up going up hills anymore.. <img src="/forums/images/graemlins/drunk.gif" alt="" />
I'm gettin 19-21mpg on worn 32's and 5.29's in the diffs.
hope this helps
<img src="/forums/images/graemlins/shiner.gif" alt="" />
84x4 Toyota Ext. Cab Deluxe
Not enough hours in the day to do what i want.....
.....and sleep
Re: ____C a r b u r e t o r s ___? ? ? ! ! ! [Re: SALMONHEAD] #749824 09/07/06 03:22 PM
dcg9381 Offline
I've used several 32/36 carbs and the 38mm.
I think the 38mm is complete overkill unless you've done some port work. I noticed no performance difference (slight mileage difference) between the two on a 22r with a mild cam, MSD ignition, header, & full exhaust.
22REturbo.net
1988 4Runner
Re: ____C a r b u r e t o r s ___? ? ? ! ! ! [Re: dcg9381] #749825 09/07/06 05:27 PM
yodta Offline
that's interesting about the 38mm. I use a 32/36 progressive, but hear from all 38mm users that it'll spin the wheels.
msg - '87 xtracab
Re: ____C a r b u r e t o r s ___? ? ? ! ! ! [Re: yodta] #749826 09/12/06 06:45 PM
ArbitraryNotion Offline
I have a 32/36 on my dad's truck and a 38mm on mine, world of difference in power. I love my 38mm.
Josh
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6190 MB (Peak: 0.7175 MB) Data Comp: Off Server Time: 2026-06-09 19:15:48 UTC
