95 Montero Code 23 problem #749939 09/06/06 05:07 PM
darkroom1428 Offline OP
Ok i'm not getting spark on 3 and 6 coil. so i pulled the code and found that my cam shaft sensor is faulting. so i replaced it with and old one off my broken engine (which was working before i throw a rod on it). now that it is installed i'm still geting the same code.
just to see what code i would get after unplugging the CRANKSHAFT sensor nothing happened i'm still geting the code 23 which is the cam sensor not the crank.
so would you think it is the crank sensor? i would test that but don't have the sensor around
thanks
lee
Re: 95 Montero Code 23 problem [Re: darkroom1428] #749940 09/06/06 05:18 PM
ryany Offline
Sounds most likely like a broken wire or bad connection at a plug in connector on your cam sensor wiring harness. Trace the wires from the cam sensor back to the ecm if you can. I would get out the wiring diagram, find the terminal at the ecm connector that the cam sensor signal comes in at, then check for continuity between that terminal & the cam sensor plug. If you have continuity, then you either have another bad cam sensor (not likely, but an outside possibility) or the ecm has a problem.
95 Montero SR
Re: 95 Montero Code 23 problem [Re: ryany] #749941 09/07/06 01:18 AM
thanks for the advice. i just decide to take apart the front timing cover and found the crankshaft sensor and timing gear damaged. seems like something fell inside. damn
Now i'm on the look out for the parts
PHP: 7.4.33 Page Time: 1.040s Queries: 15 (0.003s) Memory: 0.5933 MB (Peak: 0.6471 MB) Data Comp: Off Server Time: 2026-05-30 11:24:43 UTC
