3.0 ticking #750013 09/06/06 08:53 PM
L
lostone Offline OP
My new 3.0 is making a ticking noise. It is coming from somewhere near the dirver's side vlave cover. What could it be, theis is a brand new motor with less than 1500 miles on it. its not the distributor and if it matters I am running 10w30.
Re: 3.0 ticking [Re: lostone] #750014 09/06/06 09:34 PM
JackKnife Offline
Most likely, the fuel injectors are the cause. They tend to be quite loud.
Re: 3.0 ticking [Re: JackKnife] #750015 09/07/06 12:30 AM
U
USMCTRD Offline
I heard the same thing after rebuilding mine. It was the injectors. You can use a automotive stethascope? if you're not sure.
88 V6 4Runner, 2" 4Crawler body lift, 2" suspension, 32x11.50 Pro Comps
Re: 3.0 ticking [Re: USMCTRD] #750016 09/07/06 03:00 AM
My 3.0 runs great and has the same ticking noise. Every 3.0 I have ever owned had that same injector noise. You'll get used to it.
Re: 3.0 ticking [Re: lostone] #750017 09/07/06 05:00 AM
DirtCheap Offline
I,also have the ticking noise in the same area but it's a valve. Time to pull the valve cover!
1989 Toyota SR5 DLX SB
1995 Toy DX XTRA Cab 4x4
1989 Dodge Raider 3.0 V6, 5 spd, Michelin LTX series, bouncey seat
1988 Dodge Raider A/T w/Offroad Package
1959 Corvette
1977 Z28
1979 Honda CBX 1000 6 cyl
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6023 MB (Peak: 0.6618 MB) Data Comp: Off Server Time: 2026-11-15 02:13:58 UTC
