help finding 4.3 info #750575 09/10/06 06:16 AM
roadayo1 Offline OP
I am pretty sure I am going to do a 4.3 liter swap out of an s10 and was wondering if anyone knows any good write ups or links I could read. thanks for the help in advance.
Re: help finding 4.3 info [Re: roadayo1] #750576 09/10/06 08:41 PM
Ed Mc Offline
This should get you started:
http://www.off-road.com/isuzu/v6trooper.html
Plus, use this site's search feature on the Isuzu forums and you'll find lots of swap info.
What engine do you have in your Rodeo? If it's a GM 3.1, I'd have another suggestion for you which will require a whole lot less work.
Cheers..........ed
'90 Troop 3.4 LS
'89 Troop RS (Has Valve Issues, needs Counseling)
HI, I'm Ed and I'm a Trooper-holic!
Keep On Troopin'......
Re: help finding 4.3 info [Re: roadayo1] #750577 09/10/06 10:23 PM
mlclark Offline
Isuzu Moderator
Are you looking for a 4.3 or a 3.4? One is vastly more easy to swap.
Michael
Re: help finding 4.3 info [Re: mlclark] #750578 09/11/06 02:32 AM
roadayo1 Offline OP
I have a 3.2l with a five speed in a 94 rodeo so I thought about a 3.8/4 but I have heard that they wouldnt bolt up.
Re: help finding 4.3 info [Re: roadayo1] #750579 09/11/06 03:07 AM
mlclark Offline
Isuzu Moderator
Ok, you gotta clear up what exactly you are looking for.
So far you have mentioned:
4.3
3.8
and 3.4
If you have the 3.2, anything except the 3.2/3.5 block will require a drivetrain swap in order to work. Along with moving/making mounts, changing driveline lengths and all the associated wiring.
So...let's talk about this. What is is you are exactly trying to do? What experience do you have and what facilities/tools do you have. It is really easy to get in deep with an engine swap.
Michael
Re: help finding 4.3 info [Re: mlclark] #750580 09/12/06 01:40 AM
roadayo1 Offline OP
I have been attending a automotive tech class for two years and have done several swaps from honda to corvettes to ford rangers. I know what I am getting into and have a pretty wide range of tools excessable to me. I have been working in a corrvette shop for two and a half years so I think I am ready for this swap. If I understand correctly that no engine will bolt up to my stock tanny because it is a five speed. This is what I have planned out so far I got a drive train out of an old one ton chevy that had a 400 small block a np465 and a rockwell transfer case. But found a 1991 s10 with a 4.3 that runs good and doesnt have a bit of trouble mechanically but the body is shot. One of my good friends owns and runs a junk yard so at the same time I found this s10 I found a fullsize chevy d44 with 4.10 gearing none the less so that is going under the rodeo also but I have already had the clutch rebuilt and I rebuilt the tranny in class so next is to rebuild the engine and then swap my completely new drive train in. If you are thinking why would you do this to a rodeo then I personally dont think you have an understanding of my love for my truck. But I was looking for some write ups for tips and tricks and thought you guys would be the best to ask. thanks again sam.
Re: help finding 4.3 info [Re: roadayo1] #750581 09/12/06 04:35 AM
CPOM Offline
No big deal buddy, Mike was just trying to get some background, by no means was he questioning your intent or abilities. The background info is as much important when you ask for advice as the who what where and whys are. Anyways, I think you are on the right track by giving us some info about your situation but you might need to give even more info and specifics if you want specific help or advice. Like something to get the conversation started.
If you just want to look at pics and read buildups, I know if you search under "stinkbug" he has done a 4.3 swap with some pics a few years ago in his old Amigo. Or there are a ton of threads on pirate if you want to just read and look at pics for ideas. Good luck sounds like a cool project.
CHRIS
98 Amigo, 92 Pup
Re: help finding 4.3 info [Re: roadayo1] #750582 09/12/06 05:28 AM
randii Offline
Once again, with paragraphs...
I have been attending an automotive tech class for two years and have done several swaps from honda to corvettes to ford rangers. I know what I am getting into and have a pretty wide range of tools accessable to me. I have been working in a corvette shop for two and a half years so I think I am ready for this swap. If I understand correctly that no engine will bolt up to my stock tanny because it is a five speed...
I found a 1991 S10 with a 4.3 that runs good and doesnt have a bit of trouble mechanically but the body is shot. One of my good friends owns and runs a junk yard so at the same time I found this S10, I also found a fullsize chevy d44 with 4.10 gearing ... so that is going under the rodeo also. I have already had the clutch rebuilt and I rebuilt the tranny in class so next is to rebuild the engine and then swap my completely new drive train in.
Sounds like a cool project... here are a few links:
http://www.4x4wire.com/forums/showf...&Number=912568&Forum=c15
http://www.4x4wire.com/forums/showf...&Number=803463&Forum=c15
http://www.4x4wire.com/forums/showf...&Number=457127&Forum=c15
...if you search this forum on "+engine +swap" or "+engine +swap" you will find more.
Randii
Re: help finding 4.3 info [Re: randii] #750583 09/12/06 05:59 PM
Jim_Paget Offline
There are also a couple of threads, at least one is a 2-3 years old, on the Mitsubishi board on 4.3 transplants into 1st Gen Monteros/Dodge Raiders.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: help finding 4.3 info [Re: Jim_Paget] #750584 09/12/06 06:19 PM
Rodeo Guy Offline
Put in the 400 sbc, a 4.3 swap is barely worth the effort <img src="/forums/images/graemlins/smile.gif" alt="" />
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
PHP: 7.4.33 Page Time: 1.109s Queries: 16 (0.004s) Memory: 0.6400 MB (Peak: 0.7672 MB) Data Comp: Off Server Time: 2026-06-10 08:37:30 UTC
