Page 2 of 3 1 2 3
Re: Questions on lockers [Re: passportsplay2] #750837 09/12/06 02:49 PM
RobG Offline
So my best bet would to be to regear it. That way it will make up for my 32's and i could drop a locker in it.
If you've got an unlimited budget, sure. I won't argue this is the ideal solution.
However, you can run 32's with stock gearing and not much of a problem. Obvisously, there will be a noticable power loss, but thats to be expected. Cost wise, you wanna be at least 33"+ tire size before regearing becomes cost effective, IMHO. expect to spend over a $2k to regear your truck and add in a full case locker.
What I think your best bet if you're new to this and looking for the most bang for the buck is to confirm you have LSD (which a lot of 2nd gens do) and then go out and spend $300-400 on a lockright/noslip drop in locker. you can install this yourself on a weekend and you're done. no additional costs.
of course, if it turns out you have an open diff, this discussion changes a little.
-Rob
Re: Questions on lockers [Re: RobG] #750838 09/12/06 03:10 PM
Bigpoppax2 Offline
You could also find a full rear end that has the gear you want and put a drop in locker in it.
I found a 4.77 geared D44 off of an Amigo with disc brakes. I then found a 4.77 third member for the front. I got an Aussie locker for the rear end and I put an ARB in the front.
I'm running 285/75/16's and it's about perfect for the 4.77's.
Joe
Re: Questions on lockers [Re: Bigpoppax2] #750839 09/12/06 04:51 PM
Smiley Offline
àI found a 4.77 geared D44 off of an Amigo with disc brakes. I then found a 4.77 third member for the front. I got an Aussie locker for the rear endà
Just for the recordà
Installing that Aussie Locker into Joe's 4.77 2nd Gen Amigo axle required the use of a custom-made set of heat-treated spacer shimsà something that isn't readily available to the public (yet / if ever).
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Questions on lockers [Re: Smiley] #750840 09/12/06 04:57 PM
Bigpoppax2 Offline
Just one other note: This only applies if your second gen rear is an open rear end. If it has the limited slip diff you will be fine a no-slip will drop right in.
Joe
Re: Questions on lockers [Re: Smiley] #750841 09/12/06 06:16 PM
Rodeo Guy Offline
Actually, the front 4.77 R&P is part no. 8943160220 is $570, and the rear R&P is part no. 897179931 is $285. So if you are stuck on 4.77s, your best bet may be to order the rear set from St Charles, and get a front third from the junkyard or car-part.com. Don't get the front third member from a 98 amigo if you want to install an arb at some point, it won't fit.
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: Questions on lockers [Re: Rodeo Guy] #750842 09/12/06 06:46 PM
Bigpoppax2 Offline
And that's nice to know the gears are still available to just go buy. Problem is I only spent $85 plus shipping for the whole front third, and 300 for the whole rear axle (complete) Already geared with 4.77 both front and rear, so I didn't pay any setup fees.
So for 385, I was good front and rear, granted I picked up my rear so I saved shipping on that one. Just another option to look at.
Joe
Re: Questions on lockers [Re: Bigpoppax2] #750843 09/12/06 11:56 PM
P
passportsplay2 Offline OP
Alright so if i have a limited slip i will be able to drop a noslip locker in it? If i don't i can make shims that will fit it? I am not in no hurry to regear my truck.It was only an idea to be able to get a locker in it.
Re: Questions on lockers [Re: passportsplay2] #750844 09/13/06 12:27 AM
P
I jacked my truck up put it in nuetural and spun the tires. They both spun in the same direction. So i take it i have a limited slip. with this known what are my options on a locker and the install process. Also thank you all im still learning about my truck. It is nice to have so many experts helping me learn.
Re: Questions on lockers [Re: passportsplay2] #750845 09/13/06 12:35 AM
TrailMystic Offline
I went with the ARB rear locker because I drive in snow and ice in the mountains. Auto lockers can be quirky on snow and ice. Just something to consider. ARB's are a lot more expensive, however, and it sounds like you are looking for a cheaper option.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: Questions on lockers [Re: TrailMystic] #750846 09/13/06 02:02 AM
P
I live in Arizona i don't see snow. Yeah a cheap descent locker is all im looking for.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6401 MB (Peak: 0.7501 MB) Data Comp: Off Server Time: 2026-07-15 02:53:09 UTC
