Re: Question for superdawg or others. [Re: superdawg] #750896 09/19/06 04:18 PM
P
pauper Offline OP
Thrust washers were stuck on spider gears,DOH!. Thanx JeePete.
Everything looked fine, the springs are just as big a pain to get out as they are to get in.
On to the rear...And on that note, it appears the gas tank is in the way of removing the rear diff, with 3.43 gears I am assuming I will have to remove diff.?
Again, Thanx to all for putting up with a newbie <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Question for superdawg or others. [Re: pauper] #750897 09/19/06 09:43 PM
BobRowe Offline
When you say "remove the diff", do you mean remove the differential assembly from the housing, or do you mean remove the whole pig from the vehicle? If the latter, why?
Re: Question for superdawg or others. [Re: BobRowe] #750898 09/19/06 10:49 PM
P
pauper Offline OP
I mean remove differential assembly from housing, sorry.. And I typo'd, I meant 3.73 gears.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6006 MB (Peak: 0.6530 MB) Data Comp: Off Server Time: 2026-05-29 22:23:18 UTC
