What year Aisin hubs will fit my '95 Trooper? #750915 09/11/06 05:40 PM
mtbikerjohn Offline OP
I've been searching for manual hubs for my '95 Trooper..I found a set of Aisins on a '90 Trooper,but am unsure of the spline count for that year.I remember seeing a discussion on which years/models fit,but for the life of me,I can't find it thru search.Also I read about using Dodge Ram frt.coil spaaers on the rear coils of Isuzu's.Is there a certain model Dodge I should be looking for? My local 4wd shop has no clue whatsoever...TIA...John <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: What year Aisin hubs will fit my '95 Trooper? [Re: mtbikerjohn] #750916 09/11/06 06:02 PM
lets put it this way...which year Isuzus have the 24 spline count?
Re: What year Aisin hubs will fit my '95 Trooper? [Re: mtbikerjohn] #750917 09/11/06 06:06 PM
onebadtrooper Offline
The hubs from that 90 trooper should fit no problem. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: What year Aisin hubs will fit my '95 Trooper? [Re: onebadtrooper] #750918 09/11/06 06:50 PM
Thanks OneBadTrooper..thats what I thought..I just didn't want to get involved in pulling the hubs off and find out they were the wrong spline count.... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: What year Aisin hubs will fit my '95 Trooper? [Re: mtbikerjohn] #750919 09/11/06 08:08 PM
Richard Saylor Offline
I seem to remember reading somewhere that the older 8 bolt fronts had the 24 splines and that the newer 10 bolt had 17 spline. Hopefully someone will correct this if what I had read was wrong.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: What year Aisin hubs will fit my '95 Trooper? [Re: Richard Saylor] #750920 09/11/06 09:16 PM
TrooperJ Offline
You are correct. <img src="/forums/images/graemlins/kewl.gif" alt="" />
-J
Jordan Brown in Athens Georgia
The 2007 budget for the US Military covers Jack Bauer, two pistols and four billion rounds of ammunition.
Re: What year Aisin hubs will fit my '95 Trooper? [Re: TrooperJ] #750921 09/12/06 12:26 AM
strawmyers Offline
Isuzu Moderator
Yes'sir... newer ones are 17 spline. Any hubs from late '88 and up should bolt up just fine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean Strawmyer
Re: What year Aisin hubs will fit my '95 Trooper? [Re: mtbikerjohn] #750922 09/12/06 12:51 AM
Gizzy42 Offline
Here it is again
4x4 Pickup.......thru 85.......24
4x4 Pickup.......72û80.........24
Trooper I, II....83û86.........24
Trooper II.......87û99.........17
Rodeo............91û99.........17
Amigo............91û99.........17
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: What year Aisin hubs will fit my '95 Trooper? [Re: Gizzy42] #750923 09/12/06 05:55 AM
NATO308 Offline
Parts interchange between the older and newer Aisin hubs. The older hubs had raised ears to turn the center engagement knob, having ears that stick out a half inch further makes it a whole lot easier to turn the knob into 4 wheel drive! You can recognize the older Aisin hubs due to the fact that the Allen bolts go through the top cover to hold everything together instead of having recessed Allen bolts with small bolts to hold the top on.
'94, and '00 Amigos and '00, 01 Rodeos. Rodeo springs and aftermarket 'hard top on 94. Aisin hubs OME 919's on the 2000 Amigo. 2000 and 2001 Rodeos have OME 912's and Aisin. Smoother ride with the OME 919's???
Re: What year Aisin hubs will fit my '95 Trooper? [Re: NATO308] #750924 09/12/06 03:00 PM
BigSwede Offline
Dang, that sounds like a good thing to me...the allen bolts on my newer Aisins keep loosening up, it would be nice to be able to tighten them without having to remove the cap...
Serenity now!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6418 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-06-21 15:08:33 UTC
