LSD swap from supra #751164 09/12/06 09:04 PM
krb90 Offline OP
Does anyone know if an 8" LSD from an '88 Supra will fit in a '90 v6 4wd pickup?
thanks.
Re: LSD swap from supra [Re: krb90] #751165 09/12/06 09:08 PM
4Crawler Offline
Re: LSD swap from supra [Re: 4Crawler] #751166 09/12/06 09:10 PM
krb90 Offline OP
I did, but didn't see anything.
Re: LSD swap from supra [Re: krb90] #751167 09/12/06 09:11 PM
4Crawler Offline
Not even the article entitled "Tech: Retrofitting a Supra Limited Slip into an 8 Inch Rear Axle" I posted a link to above?
Re: LSD swap from supra [Re: 4Crawler] #751168 09/12/06 09:14 PM
krb90 Offline OP
Ohhh, THAT one........
Thanks, I appreciate it.
Re: LSD swap from supra [Re: krb90] #751169 09/12/06 09:24 PM
krb90 Offline OP
Do you (or anyone) know if shortening the axles 1/8" as described in the article will effect the factory open diff if the swap is reversed? Or, once you do this swap, there is no going back (unless you invest in new axles).
Re: LSD swap from supra [Re: krb90] #751170 09/12/06 09:52 PM
4Crawler Offline
Don't know for sure, but there is typically well over 1" of axle shaft inside the diff, like 1-1/8" to 1-1/2", and the very end is usually chamfered anyway, so 1/8" less should not make much, if any difference.
Re: LSD swap from supra [Re: 4Crawler] #751171 09/12/06 10:15 PM
Staceman Offline
The LSD from an 88 Supra will do just fine. ZUK did mine actually. And no, you DO NOT NEED to cut your axle shaft. Mine is a narrow '85, my neighbors was a wider '86. Neither one required shortening. Here's ZUK's write-up on mine.
Note the bearing cup difference on one side. That's all.
ZUK's LSD install
Re: LSD swap from supra [Re: Staceman] #751172 09/12/06 10:45 PM
krb90 Offline OP
Good write up, explaination and pictures......also another one: Supra LSD into an open V6 3rd
Many thanks.
Re: LSD swap from supra [Re: krb90] #751173 09/13/06 12:49 AM
mosk Offline
We did this swap into my '86 turbo rear end last year and I've been very pleased with it. I don't do much wheeling these days, but I do drive hard on the street, and the Supra LSD rear is great for that. Stock axles fit without incident.
-Jeff
Jeff Moskovitz
1986 turbo 4X4 truck
1998 2.7L/M5 4X4 4Runner
Jeff's 22R-TE page
22RTE Turbo Truck Forum (advertising free)
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6423 MB (Peak: 0.7614 MB) Data Comp: Off Server Time: 2026-06-23 19:45:06 UTC
