Re: LSD swap from supra
[Re: mosk]
#751174
09/13/06 02:53 AM
Will the Supra LSD only fit 4 pinion diffs (Turbo & V6) or will it fit the 2 pinion (4 cyl) as well?????......
[Re: trcdrunner]
#751175
09/13/06 07:42 AM
No 4cyl/2pinions carrier. Only v6/4 pinion carrier works because you need to save one side of the FAT v6 truck bearing (including outer- race) to press onto one side of your supra LSD. I regret that I did not shim the springs for the friction plates inside the LSD & I totally recommened you to do so. Don't forget to add a bottle of LSD additive into your gear oil. I got mine for $4 from Ford dealership.
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/ Camper/33x10.5BFG-AT/Open 4:88/1.5"BJS/ +2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
[Re: allochris]
#751176
09/13/06 01:37 PM
how do those run in the snow/ice?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5991 MB (Peak: 0.6524 MB) Data Comp: Off Server Time: 2026-06-18 13:09:48 UTCValid HTML 5 and Valid CSS
