Toyota truck welding projects #752452 09/18/06 07:02 PM
1
10_35lookoutbelow Offline OP
Hey I just got a new welder last week and I am looking for some ideas on what some of you guys have welded up on your rigs to improve off road ability, add utitity, add strength, look cool, etc...
I am already considering building a rear bumper, adding a front range off road style severe use front gusset, and mabye some nerfs?
C'omon I know some of you guys have been slaving away on your projects this summer! Show and tell lets see em.
Theresa the Toyota Terror-89 Toyota P/U (3.0L SR5, 5sp swapped in from auto, 3"B.L., 32X11.5X15 MT/R, 2.5" stainless magnaflow catback exhaust, leaky floor with cold draft @feet, FUBAR comptron now in glovebox)
Re: Toyota truck welding projects [Re: 10_35lookoutbelow] #752453 09/18/06 09:40 PM
willzrunna96 Offline
rocksliders and a sas are always a good project, i wish i could weld instead i just burn hole in everything!!
Re: Toyota truck welding projects [Re: 10_35lookoutbelow] #752454 09/18/06 11:48 PM
eightyeight Offline
for me its been- sas, rear spring swap (chevys), FIXING RUST HOLES, and tons of little stuff. i plan on making bumpers and sliders as soon as time and money allow.
welding is probably the single most useful skill when building trucks, other than basic mechanical knowledge.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: Toyota truck welding projects [Re: 10_35lookoutbelow] #752455 09/19/06 12:47 AM
4xJedi Offline
Rear cargo rack which mounts a High-Lift.
Another shot of the rack and my bumper.
25deg. sliders.
Front bumper.
Welding cart.
Oh yeah, the tube bender helps <img src="/forums/images/graemlins/notooth.gif" alt="" />.
'86 4Runner 5" SAS
'97 4Runner
'05 Corolla
'00 F250 PowerStroke
Re: Toyota truck welding projects [Re: 4xJedi] #752456 09/19/06 02:17 AM
TheBandit Offline
You can make a lot with a welder, chopsaw, and angle grinder. Here are some of my projects that I've used my welder for, working from easier to more complicated.
Rear bumper: http://www.extremefabricator.com/BB/viewtopic.php?t=68
Swing-Down Hi-Lift Carrier http://www.extremefabricator.com/BB/viewtopic.php?t=68
Rock Sliders: http://www.extremefabricator.com/BB/viewtopic.php?t=13
Factory AC + On Board Air Bracketry: http://www.extremefabricator.com/BB/viewtopic.php?t=45
Rear Wheeltubs: http://www.extremefabricator.com/BB/viewtopic.php?t=14
Tube Front Bumper: http://www.extremefabricator.com/BB/viewtopic.php?t=51
I can't begin to tell you how many other projects unrelated to my truck that I've used a welder for. If you get addicted to this stuff, you will have a list of things you want to do that far exceeds how much time you have available. For a beginner welder, I would start with box tube bumpers and sliders and make more stuff as your skill improves.
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: Toyota truck welding projects [Re: TheBandit] #752457 09/19/06 02:25 AM
I look forward to building my own bumpers......just as soon as I finnish welding the rust up smile
Re: Toyota truck welding projects #752458 09/19/06 04:55 AM
Scerb Offline
<img src="/forums/images/graemlins/wink.gif" alt="" />
Those are Tyler's sh1tty welds btw. My diff <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Toyota truck welding projects [Re: Scerb] #752459 09/19/06 06:15 AM
jasonmt Offline
Having current pass through roller bearings is generally a BAD thing with a decidedly negative impact on bearing life if the current happens to arc from a roller to race.
Hence the reason you should connect the ground clamp to the carrier rather than the housing in order to prevent this.
Re: Toyota truck welding projects [Re: jasonmt] #752460 09/19/06 07:52 AM
TheBandit Offline
X2 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Toyota truck welding projects [Re: 10_35lookoutbelow] #752461 09/19/06 08:06 AM
Snowtoy Offline
Here is some of my projects.
Front Bumper
Skid Plate
Rock Slider
Rear Bumper
Roof Rack
'86 Front Bumper
'91 Flatbed project
Plus plenty of other items such as seat mounts, body panels, onboard air tanks, and exhaust systems(a couple of these and the welder pays for itself), then there are all the non-auto related items. I have found my welder to be as essential to my garage as a standard set of tools.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.005s) Memory: 0.6387 MB (Peak: 0.7656 MB) Data Comp: Off Server Time: 2026-10-25 16:06:48 UTC
