trailer wiring???? #752477 09/18/06 08:53 PM
Jonesy Offline OP
Ok, I am having a hard time wiring up my trailer lights. Here is where I sit.
I have the wiring connection from inside the car(beat up, and the plastic connection piece is destroyed, but I have it) Anyway, I have 5 wires within what was once a single "plug" that I believe is the wiring jack. It is coming from the passenger side(this is on a 97) It is wrapped withing the ground for the fuel pump(connected to the rear crossmember)
Now, I spent the better part of an hour trying to wire it to a 4-plug connection from Pep Boys. I have 5 wires(black, green green/red, red and can't remember the other 2) On the 4 pin I have white, yellow, brown, green. So far, I believe it goes,
4 pin Car
white black
green green
yellow one of the unnamed
brown ??????
I played around, and couldn't get it right. If I had the brown(which should be brake lights for both sides) wired to the red...the trailer lights, however don't glow bright like brake lights. I can get the signals to glow bright, but am having trouble getting the parking/brake lights to work right.
Does anyone know how this is supposed to work? What is the left over connection for? I may just have to wire it fresh...but don't really want to.
Also, the trailer works with other cars, so I know it's wiring is correct.
Also, the Haynes I have...is not very clear when it comes to this accessory wiring.
Thanks,
Steve
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: trailer wiring???? [Re: Jonesy] #752478 09/19/06 02:03 AM
Gizzy42 Offline
You need a converter for import cars. It combines the turn signal with the brake lights.
Trailer wire colors
Brown - tail lights
Green - right turn and brake light
Yellow - left turn and brake light
White - ground
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
PHP: 7.4.33 Page Time: 1.174s Queries: 15 (0.004s) Memory: 0.5885 MB (Peak: 0.6380 MB) Data Comp: Off Server Time: 2026-06-17 06:28:20 UTC
