Page 2 of 3 1 2 3
Re: Electric radiator fan [Re: Airdale73013] #752733 09/21/06 11:53 PM
Everet Offline
And if that isn't enough, you might need to park a Bell Helicopter under the hood. <img src="/forums/images/graemlins/lol.gif" alt="" /> Hayden recommends 2 fans that have a combine flow of 2500 cfm (free flow) for a 350 V8. But then again, anything worth doing is worth overdoing...
Everet
Re: Electric radiator fan [Re: Nukeiridium] #752734 09/22/06 01:58 AM
DEFBOY35 Offline
main reason im going with the 16" is, it was free.
i suppose that if its not necessary to go bigger, there is no need as it will probably just be more taxing on the electrical system when running. how much, i dont know.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: Electric radiator fan [Re: DEFBOY35] #752735 09/22/06 07:36 AM
fokion Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
That's the best reason!!!!!!!!!!!!!
Still need the info on the controler...
Re: Electric radiator fan [Re: fokion] #752736 09/22/06 01:26 PM
A
Airdale73013 Offline OP
If you are speaking of the Spal Fan Controller go to www.spal.com and look at the FAN-PWM controller.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: Electric radiator fan [Re: Airdale73013] #752737 09/25/06 07:09 PM
A
I installed the fan and controller Saturday, I expected it to take a bout 3 hours but alas it took 7 hours. Removing the mecanical fan assembly was not difficult. Removing the a/c condensor fan was a little more difficult but only because the grill had to be removed first. The shorter replacement alternator belt I used is a Gates K040330 (14mm x 855mm), I would not reccommend you use a shorter belt than this.
The most difficult part of the install was mounting the fan in the existing fan shroud. It took several hours to figure out the mounting and to fabricate the mounting hardware.
The controller installed on the driver side fender pannel just behind the headlight. The wiring included with the kit was long enough and I routed the power wiring, oem temprature sensor, fan power, and the a/c sensor lead across the radiator fan shorod, I attached the wiring in three places with zip-ties. I connected the ignition sens leat to an existing wire on the aftermarket cruse control.
I programed the fan controller as per the included instructions, 160 degres F for low temp and 200 degres F for high temp. The fan comes on and runs at 50% at the low temp and increases in speed as the temp goes up until the high set point when it switches to 100%. If the a/c is turned on the fan will run at 100%.
I did take pictures but I don't know how helpful the will be because there is not much to see.
Also a note, you do not have to remove the top radiator hose to remove or re-install the fan shroud.
If any one is intrested in the photos I will be happy to email them to you. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Electric radiator fan [Re: Airdale73013] #752738 09/25/06 07:42 PM
Everet Offline
I decided that "BIGGER IS BETTER" so a 16" procomp is on order now. Please send me any pics of how you mounted the fan to evlu@comcast.net
Thanks,
Everet <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Electric radiator fan [Re: Everet] #752739 09/26/06 03:13 PM
Everet Offline
Thanks for the pics!
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Electric radiator fan [Re: Everet] #752740 09/26/06 04:52 PM
Nukeiridium Offline
Hmm well the fan I used was a cheapo Empire fan from Autozone so maybe it's a good thing I got a big one, since it's a cheapie... I don't know what the CFM rating is on it...
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: Electric radiator fan [Re: Nukeiridium] #752741 09/26/06 11:38 PM
A
The ProComp I purchased from an ebay storewas only $41.50 delivered. I thought that was pretty cheep.
Re: Electric radiator fan [Re: Airdale73013] #752742 09/27/06 12:02 AM
Everet Offline
Mine too! And it has a lifetime warranty....for what that is worth! Hope I never have to find out.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6453 MB (Peak: 0.7502 MB) Data Comp: Off Server Time: 2026-06-09 23:33:38 UTC
