Re: Can fuel gauge senders be fixed? [Re: stock87] #753649 09/25/06 04:41 AM
Robinhood150 Offline
Yeah, you got it now. That is strange that you're reading 110 ohms on the dot. Anyway, I think the only way to figure out what it is, is to drop the tank and take a look.
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: Can fuel gauge senders be fixed? [Re: Robinhood150] #753650 09/25/06 06:58 AM
stock87 Offline OP
Checked all the wiring, filled up to full. I originaly thought my tank had been siphoned, but it only took half a tank, which is where the needle was before the gauge dropped.
I checked the wiring all the way to the cluster and checked the resistances across the back of the gauges. It's definitely the sender. Like I said, it's less than 4 years old. Actually I'll check. Replaced 6/10/2003, factory part.
Cali truck with zero rust.
Now I just gotta wait for the tank to run down from full I guess. I'll post back when I find more out.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Can fuel gauge senders be fixed? [Re: jasond] #753651 09/26/06 01:07 AM
Snowtoy Offline
Read this before buying at tap, then make your own decision...
Yes, TAP has its problems and I try to buy as little from them as I can, however they were the cheapest in the area for a fuel sending unit last spring.
Try these guys Olympia 4x4's , they part ouit Toyotas as well, and their prices aren't to bad. I got a bumper end cap for $10, when everyone else wanted $25-45 for one. If you can't find the part online, they have a 1-800 number to contact them directly.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5996 MB (Peak: 0.6538 MB) Data Comp: Off Server Time: 2026-06-06 21:58:45 UTC
