Re: T-bar wght capacities??????? [Re: Bansil] #754184 09/27/06 07:02 PM
mlclark Offline
Isuzu Moderator
Doug-
I think you may see more fatigue from the extra weight, not failure. They are not going to twist in half (torsional failure) unless there is an inclusion or stress riser and even then they are probably going to fracture longitudinally, not torsionally (i.e. splinter, vs twisted splines on an axle.)
Afterall, they are just spring steel and that will fatigue I think you will probably see some sagging over time. How much? Who knows. You may have to re-index a few times until they need to be replaced, but outright failure is probably not a concern.
Michael
Re: T-bar wght capacities??????? [Re: mlclark] #754185 09/28/06 02:28 AM
maxwell417 Offline
This weekend I accidently reindexed my right t-bar. While dropping the front axle out swapping in my new 5.38 lsd axle assy. Maybe 3~4 splines, was cranked to the max, now I have extra threads showing.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: T-bar wght capacities??????? [Re: Richard Saylor] #754186 09/28/06 03:23 AM
88SuperTrooper Offline
Only Time i have seen T-bars get really screwed up was from PURE stupidity PURE to the Purest Form. Sadly it was a Chevy..... BUT it was twisted and broke from using a LONG wheels base on some rocks they should not have been on, got it hung up pretty bad and then his buddy was trying to yank him out BY THE TORSION BARS!!!! Back and Forth they went till it gave out. With a 6 pack and movie in front of you, why continue to wheel...
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5980 MB (Peak: 0.6513 MB) Data Comp: Off Server Time: 2026-06-19 23:17:15 UTC
