Re: 22r Carburetor Rebuild [Re: sindersblue] #754831 10/04/06 03:16 AM
yodta Offline
This one (GP Sorensen) had them though I didn't use them.
I just used a micro thin spread of hi temp RTV.
the RTV mostly likely won't last. gas will eat right through it and you'll end up with a vacuum leak. if you're going to use a sealant, you need something like Gas-ga-cinch
msg - '87 xtracab
Re: 22r Carburetor Rebuild [Re: brownguy] #754832 10/04/06 05:20 AM
Davepet Offline
if i were to use the NAPA carb rebulding kit would i get the new seals for the shaft for the butterfly valve.
I've never seen seals for the throttle plate shaft in a rebuild kit. I think the shaft is just a machined fit & if it's worn to the point yours seems to be, replacement is probably your best option.
Dave
Re: 22r Carburetor Rebuild [Re: Scerb] #754833 10/05/06 01:53 AM
brownguy Offline
I'm not sure what "shaft" you are referring to as having a vacum leak. Clarify that and I'll do my best to diagnose it.
X2 on getting the more expensive rebuild kit.
-Scerb
the shaft i'm talking about is the the throtal link basicly attached to the butterfly valve , iwas told by toyota that the rubber O-ring seal is gone causing a vacume leak (this is from talking to one of the techs)
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.005s) Memory: 0.5993 MB (Peak: 0.6528 MB) Data Comp: Off Server Time: 2026-06-10 01:32:42 UTC
