Page 3 of 4 1 2 3 4
Re: ignition bypass [Re: RLBomber] #755146 10/04/06 12:59 AM
coachj Offline OP
WELL I THINK I WILL PUT NEW PLUGS AND WIRES, CAP AND A BUTTON, JUST TO EASE MY MIND, I HAVE REPLACED EVERYTHING ELSE,VAC-LINES FILTERS, JUST TO SAY I DID THAT...THEN IF THAT FAILS,,,,IT'S INJECTION TIME....TO NICE OF A RIDE TO JUST LET HER SIT, IT NEEDS TO BE SEEN,, SHE LOOKS GREAT JUST SITTING IN THE SUN, BUT I WANNA BE SEEN WITH THE WIND IN MY FACE <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />BESIDES CHEVY MAKES A FINE ENGINE AND TRANNY,NUTTIN BUT A THANG...IF YOU GONNA JUMP JUMP HEAD FIRST....THANKS FOR ALL THE HELP WE WILL SEE WHATS NEXT WITH THE OLE GIRL
Re: ignition bypass [Re: coachj] #755147 10/04/06 02:50 PM
superdawg Offline
No need to YELL!
Those things is where one should start, not jumping into bypasses.
EFI and never look back, If you go with Howell, spend the extra $$ for the Vehicle speed sensor option and the heated O2 sensor. If running an automatic, get the park neutral switch option too. Adding these things to the basic system makes it start and drive like an OE GM truck.
SD
Re: ignition bypass [Re: superdawg] #755148 10/04/06 10:06 PM
coachj Offline OP
BUT SEE I HAVE THIS ANGER THING GOING ON WITH THIS JEEP, I CHANGED ALL THE FLUIDS WIRES AND PLUGS NOT TOO LONG AFTER I GOT IT, AND WHAT DID THAT GET ME,,,A BUSTED PISTON. IT SEPERATED AT THE SPOT WHERE THE BOTTOM OIL RING WAS,SO I DID NOT CHANGE THE PLUGS OR WIRES OR CAP AND BUTTON ON IT CAUSE IT DID NOT HAVE 1000 MILE ON IT, FROM THE LAST TUNE UP, I JUST FIGURED IT WOULD NOT NEED IT, WELL IT NEEDS SOMETHING WHAT I DONT KNOW BUT SHE IS SICK AT IDEL. DOWN RAGE RUNS GREAT...SO I JUST FIGURED IF I WAS GONNA KEEP HER I WOULD TRY AND DO THE BEST FOR HER.
Re: ignition bypass [Re: coachj] #755149 10/04/06 10:33 PM
BigJim Offline
Howdy coach I don't know about that yelling deal...it seems sily to me! I guess a bunch of pansys thought that up! As long as you print in almost english I can read it.
Tell me more about that piston! Did you pull the valves on that cylinder and look closely at them? A bad idle can be caused by a small intake valve leak.. which in turn does not matter to increased speed...they will run good at speed till the valve leak gets larger.
Re: ignition bypass [Re: BigJim] #755150 10/05/06 12:12 AM
coachj Offline OP
YEAH HAD THE HEAD REBUILT..WHEN THE PISTON BROKE, IT WAS LIKE IT HAD BEEN CUT WITH A KNIFE, THEY TOP PART STAYED UP AND THE PART THAT WAS STILL HOOKED UP, WAS HITTING THE OTHER PART EVERY TIME IT MADE A STROKE, BUT REGUARDLESS I HAD IT RE-BUILT, VALVE-JOB HAD THE SPRINGS CHECKED,,,ALL THAT GOOD STUFF....JUST DONT UNDERSTAND WHAT HAPPENED,,,HAVENT DONE ANYTHING TO THAT CARB,,,,BECAUSE I HATE THEM WITH ALL THE WIRES AND CRAP....I LOVE THE OLD WAY..ONE VAC-LINE TO THE DIST...ONE TO THE TRANNY...AND CHOKE PULL OFFAND UR DONE, NOT THIS 10,000 LINES RUNNING EVERY WHERE UNDER THE HOOD....I HAVE NO LEAKS NO WHERE,, CHECKED ALL MY VAC-BOWLES...IT'S NOT GONNA GET THE BEST OF ME... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: ignition bypass [Re: coachj] #755151 10/05/06 06:04 AM
BigJim Offline
Coach after that kind of repair it is a VERY common thing for the intake manifold gasket to have a small leak... Why not retorque all the bolts on the manifolds.. Can't hurt.
Re: ignition bypass [Re: BigJim] #755152 10/05/06 03:04 PM
coachj Offline OP
WILL DO BIG JIM,, I KNOW WHAT EVER IT IS WILL BE SIMPLE AND PROBABLY LOOKING ME RIGHT IN THE FACE...SHE RUNS TO WELL FOR IT TO BE BAD....PLUS IT HAS NOT AFFECTED MY GAS MILAGE YET,,, DOING WELL ON THE NEW ENGINE
Re: ignition bypass [Re: coachj] #755153 10/08/06 02:56 PM
coachj Offline OP
BIG JIM....I WAS DRIVING THE OLE GIRL AROUND SOME MORE TODAY AND NOTICED MY TEMP GAUGE HAD QUIT WORKING, CHECKED ALL THE CONNECTIONS TO MAKE SURE THEY WAS TIGHT,AND THEY WAS. HOW CAN I TEST THE UNIT SO SEE IF IT WENT BAD,OR TEST THE WIRE, I LOOKED AT THE GAUGE ONE TIME AND IT READ ABOUT 195-200 AND A LITTLE LATER I GLANCED DOWN AND IT WAS SETTING ON THE 100 MARK, WHICH IS WHERE IT REST ON THE PEG WHEN IT COLD, THANKS FOR YOUR TIME
Re: ignition bypass [Re: coachj] #755154 10/08/06 03:53 PM
BigJim Offline
Well coach like they say "spit happens"! You can look up the resistance of the sending unit and compare it to what you have now... But in similiar situations I have always simply installed a new sender and it has always been the culpret. So Id advise purchasing a new one and installing it to see if the gauge goes back to work for you.
There is a central ground for all the gauges so usually if one does not work ALL fail.
Re: ignition bypass [Re: BigJim] #755155 10/09/06 01:16 AM
coachj Offline OP
hey jim right off hand do you know what size drill bit i need for a 1/4 pipe thread...re-do a sending unit on the head
Page 3 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6377 MB (Peak: 0.7465 MB) Data Comp: Off Server Time: 2026-06-17 13:07:51 UTC
