Questions regarding parts, and where to get them... #755485 10/03/06 01:04 PM
Billdo Offline OP
I am recently going to be swapping out my Cylinder Head with a new Head from AMC, I am also going to be replacing my Timing Belt as well.
Where is the best place for me to get a timing belt and should I get a new tensioner as well at the same time?
Also what gaskets will I need to put everything back together, I have a header and not the exhaust manifold.
Also I am currently talking with Joe about ordering the Diff drop bracket and I am going to have to replace my CV boots, maybe even the joints as well here shortly. best place to buy CV joints and boots? The boots are badly ripped up and I will need to do so before winter, so I don't get any kind of crap in my CV joints.
I also have a new 3" body lift sitting at home waiting for me to get back inport so I can install it. Where can I go in the Seattle area that will weld the new shifter extensions on for me? I am pretty sure I can install the pucks myself.
Sorry so long of a post, but I am trying to get as much stuff done to my rig while I am still out here so I can take it up into the mountains, I would really like to run the Naches trail before I leave. I am due to rotate out of the PNW sometime next May. Maybe even sooner. I will soon be making E-6 and as a present to myself I will be buying new gears and a Tera low kit, but I have to advance to the next higher paygrade before I do that.
Thanks for your help..
Bill
2000 Chevy Tahoe nothing special. 1990 Isuzu Amigo, 3" lift, 31x10.5x15 BFG All Terrain (Street), 33x12.5x15 (offroad), Pacesetter header, some ATM rash. More mods to come......
Re: Questions regarding parts, and where to get them... [Re: Billdo] #755486 10/03/06 08:30 PM
CPOM Offline
timing belt, tensioner : st charles isuzu (www.stcharlesauto.com) for OEM stuff
CV boots - independent4x.com for mecatech kits, stronger than OEM
congrats on the promotion
CHRIS
98 Amigo, 92 Pup
Re: Questions regarding parts, and where to get them... [Re: Billdo] #755487 10/03/06 11:08 PM
Troopersphere Offline
I've found www.rockauto.com to be pretty good for non-oem stuff... but I did get OEM parts in several of my orders. I think all the on-line parts houses are pretty much the same network of parts dealers...
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Questions regarding parts, and where to get them... [Re: Billdo] #755488 10/04/06 12:15 AM
pucci Offline
Importec sells a lot of OE brand parts and higher quality aftermarket stuff too. depending on the part some of their prices are super low, some not- you have to compare & shop selectively.
I've been doing business with them for years & the customer service is top notch. <img src="/forums/images/graemlins/kewl.gif" alt="" />
2.6 Trooper
2.0 Impulse Turbo
Re: Questions regarding parts, and where to get them... [Re: Troopersphere] #755489 10/04/06 01:47 AM
88SuperTrooper Offline
I have used RockAuto with No Problems and they also have a core return so you do get some money back. They had me sold On my Fuel Injectors when I saw the Price. 146.99 for a set of 4 and with the 12.00 each on core's I still had money to put in to other Parts.
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: Questions regarding parts, and where to get them... [Re: 88SuperTrooper] #755490 10/05/06 12:02 PM
Billdo Offline OP
Ok, but which gaskets should I get besides the head gasket, and should I replace anything else other than the timing chain while I have it open, maybe the oil pump?
Re: Questions regarding parts, and where to get them... [Re: Billdo] #755491 10/07/06 12:01 PM
Billdo Offline OP
ok, I guess I should re-word my post...
which gaskets should I replace other than the head gasket when installing a new head?
Re: Questions regarding parts, and where to get them... [Re: Billdo] #755492 10/07/06 04:12 PM
pucci Offline
for sure cam oil seal. intake & exhaust manifold gaskets depending on age & condition of originals. with everything apart down below, perfect time to replace the seal on the oil pump and crank if warranted.
2.6 Trooper
2.0 Impulse Turbo
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6201 MB (Peak: 0.7189 MB) Data Comp: Off Server Time: 2026-07-12 22:38:11 UTC
