89 trooper (leaf spring) #755601 10/04/06 01:20 AM
milehighcowboy Offline OP
Ok so i am pretty sure that i am going to buy this 89 trooper. it is only 400 bucks. lol. i think its a good deal. there are some things wrong with it how ever. there is an oil leak. he says that when the engine runs you can see the leak and it oozes oil. he doe not know where the leak is exactly. the muffler has to be welded together or something. but thats no big cause i can take it to my old welding shop and have my teach do it for real cheap. and then there is a broken leaf spring. or actually the center metal peice on the spring i guess.
now for my question sence i want to lift the vehicle does this broken spring help me because i will have to replace them any way or hurt me cause its one more thing to fix? what are some good part sites i can check out for some prices? thanks
Re: 89 trooper (leaf spring) [Re: milehighcowboy] #755602 10/04/06 01:54 AM
V
VOLTRON Offline
well there is independent4x.com and I dont know if darlingtonoffroad is still open but they have some good parts too. Also, there is calmini.com who have lift kits aswell.
As far as the leaf spring goes, you can just get new ones for the rear but there are also add a leafs that go inside the existing leafpack. If you go the addaleafs then you will need to get a new leaf spring or see if your busted leaf spring can be rewelded.
NOT ALL WHO WANDER ARE LOST
Re: 89 trooper (leaf spring) [Re: VOLTRON] #755603 10/04/06 02:02 AM
ok thanks. i will check that out when i see the vehicle on Thursday.
Re: 89 trooper (leaf spring) [Re: VOLTRON] #755604 10/04/06 02:06 AM
88SuperTrooper Offline
I just tried Darlington and Its a no go.... <img src="/forums/images/graemlins/frown.gif" alt="" /> I would look into having rewelded. Save $$ If thats possible.
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: 89 trooper (leaf spring) [Re: 88SuperTrooper] #755605 10/04/06 02:47 AM
mlclark Offline
Isuzu Moderator
I won't say you "can't" weld a leaf spring, but it is pretty dumb idea (and it won't work). Unless you need to do it to get out of the woods because you are being chased by homicidal midgets, it is not even worth trying. Even then, the midgets are going to get you anyway.
Other than the enormous amount of stress that a leaf spring sees, welding it changes the "spring" properties of the leaf and that kind of concentrated heat will never ever ever EVER allow the spring to do its job.
Just get a pack from the junkyard and swap leaves as needed.
Michael
Re: 89 trooper (leaf spring) [Re: mlclark] #755606 10/04/06 03:23 AM
ok so does the broken spring effect lifting the truck?
Re: 89 trooper (leaf spring) [Re: milehighcowboy] #755607 10/04/06 03:30 AM
mlclark Offline
Isuzu Moderator
Read above.
If you lift by replacing the spring packs, then no.
If you lift by adding leaves to the existing spring packs, then yes.
Michael
Re: 89 trooper (leaf spring) [Re: mlclark] #755608 10/04/06 03:38 AM
ok sorry i am new at this whole 4x4 thing. i can fix by books and my dad knows some things. my appalogies. but thanks for the help. i might have some more questions after i look at it.
Ben
Re: 89 trooper (leaf spring) [Re: mlclark] #755609 10/04/06 07:44 PM
randii Offline
Agreed, BTW, on welding a leaf spring being a trail fix, and not a great long term idea. You can stick 'em together for the short term, but you'll take the temper out of that area of the spring and it will break at the weld or next to it quickly...
Michael, I'm trying to picture where you 'wheel (question 1) where you are being chased by homicidal midgets (question 2)? Neverland Ranch, perhaps, and the natives have gone feral? <img src="/forums/images/graemlins/smile.gif" alt="" />
I think you should try live-trapping them to test for double-jointedness. Perhaps they might be domesticated a DJMs? <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Randii
Re: 89 trooper (leaf spring) [Re: randii] #755610 10/04/06 07:51 PM
RobG Offline
forget the welding... if you need a budget option, any spring shop can easily make you a custom replacement leaf... find a place that does big truck springs and it costs next to nothing for our piddly little leaves.
-Rob
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6371 MB (Peak: 0.7614 MB) Data Comp: Off Server Time: 2026-11-16 12:31:09 UTC
