Damn transfer case filler bolt....
#755754
10/04/06 11:39 PM
Ok I exhausted about everything I could try getting the transfer case filler bolt off. The PO stripped the bolt out so I tried getting a pipe wrench on there with heat (from a little propane torch)to no avail. I also tried hammering a wrong sized socket on there and use a breaker bar. That also didnt work. Next I tried the world's largest pliers with no success.....
I know the little propane torch is not putting out much heat so I held it on there all the while tapping the head with a small hammer. I'm about to go pay someone to remove it for me unless you guys have more suggestions.
~Jake
Re: Damn transfer case filler bolt....
[Re: ciscofreak]
#755755
10/05/06 01:11 AM
weld a socket to it.
94runner: Dana 44 SAS, 35's, Lockers, gears, winch, rock rails, bumpers, 3"BL, drivetrain lift, Budbuilt cross member, centerforce clutch and MORE! ***FOR SALE*** $8,500 -1985 Supra (STOCK!) FOR SALE $4,000 www.celicasupra.com
[Re: J94_4runner]
#755756
10/05/06 02:37 AM
I once used an air hammer with a wedge type chisel to break a differential filler plug loose. One thing though, you will need to get a new filler plug from the dealer
[Re: 5150]
#755757
10/05/06 02:52 AM
both of the ideas above are the best way ive don them both!
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: willzrunna96]
#755758
10/05/06 03:05 AM
I usually weld an old nut to the head of the plug then use that to remove the old plug. Frequently the heat of welding is all it takes to loosen up the plug. Replace it with one of the socket head plugs.
[Re: ciscofreak]
#755759
10/05/06 04:11 AM
You could use a Dremel-type tool to cut a slot into the bolt head, then use a B.F. scewdriver to remove it.
[Re: Pluton]
#755760
10/05/06 05:01 PM
Thanks for the suggestions. I will pick up an air chisel tonight and have at it!!
[Re: ciscofreak]
#755761
10/05/06 05:26 PM
Also, use the small torch to heat up the transfer case around the bolt, and not necessarily the bolt itself. What will happen (hopefully) is that the heated metal of the transfer case will expand (in micro-millimeters, anyway) around the bolt and remove some of the friction from the threads. That, combined with a hammer and chisel (or air, if you prefer) might do it.
[Re: krb90]
#755762
10/05/06 06:40 PM
the welding stuff is the best way if you have a welder. I didn't, and had a recent similar problem with my transmission fill plug, so I ended up drilling it and using a bolt extractor.
msg - '87 xtracab
hammer and chisel
[Re: yodta]
#755763
10/05/06 09:00 PM
It is OK if you chisel off a chunk or two while you try to back it off. It seals around the edges, usually, you get enough of the edges off and it screws right out. get a new plug while you are out air tool shopping. I too like the socket head plugs.
