Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: JLEMOND] #755969 10/16/06 01:25 AM
pucci Offline OP
gotten some more road time including high speed freeway action, narrow windy roads with elavation changes & even a few crowded rush hour trips.
given the many poor quality roads in NJ and even worse drivers, I've now had ample situations that required sudden & heavy braking:
I'm extremely pleased with the performance, if not a little impressed!
pedal is very tractable and the level of stopping power easy to modulate.
an absurdly fast yellow light with a local officer sitting at the intersection resulted in a 50-0 (very!) short distance stop - only had to use what felt like 1/2 the pedal stroke to rein it in with total control.
Sounds like a great idea, especially if you have oversize tires...
from a purely safety perspective I agree 100%
2.6 Trooper
2.0 Impulse Turbo
Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: pucci] #755970 10/16/06 07:01 AM
barak Offline
Sounds like a good swap , but the problem here is getting the parts.I can get the rotors , pads and calipers no problem.But the caliper brackets and dust shields won't be easy.Not a lot of isuzus show up at the wreckers , and the ones that do are usualy first gen troopers with the 4 cylinder that the engine is toast so they crush them.
Also its too bad that the rear can't be upgraded also.That would improve overall performance even more with all 4 brakes being beefed up.
Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: barak] #755971 10/30/06 08:40 PM
pucci Offline OP
more feedback:
I just completed a 2500 mile drive. Trooper had a full cargo box on the roof, and with the back seat up the rear was loaded with stuff - pretty heavy stuff including a transaxle, transfer case, differential, air compressor, tools, boxes of parts, etc.
steep grades, rush hours in a few cities, and of course lots of 18 wheelers jockeying for position- the brakes really were able to keep things in control with all the extra heft.
among the roads covered was the 260-277-Beeline route that drops down the Mogollon rim, lots of 6* grades with very sharp curves and plenty of disturbing skid marks, mangled guardrails and car-b-que spots on the pavement. <img src="/forums/images/graemlins/scared.gif" alt="" />
not once did i feel like i didn't have enough stopping power with all that weight.
all in all I'm really glad i did this, minimized the pucker factor for sure.
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
2.6 Trooper
2.0 Impulse Turbo
Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: pucci] #755972 11/01/06 06:22 PM
I
islandracer Offline
Nice upgrade! However, I'm still working on trying to go faster than stopping faster... <img src="/forums/images/graemlins/notooth.gif" alt="" />
B.Y.E. ~ Back Yard Engineering
Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: islandracer] #755973 11/02/06 02:44 AM
Gizzy42 Offline
The answer to that is right there in his update post..
lots of 6* grades
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Nice upgrade. Some of the heep drivers scare me, put 36-38" tires on with stock brakes <img src="/forums/images/graemlins/scared.gif" alt="" />
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO on US Wheel 94 series
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 50 series SUV 2.25"
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: Gizzy42] #755974 11/04/06 08:19 AM
lttlbddy Offline
Will the swap work with the 15" snowflake rims? Since adding the 35s I could definetely use a brake upgrade.
Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: lttlbddy] #755975 11/04/06 08:39 AM
pucci Offline OP
yes, I'm running those rims with 33's
2.6 Trooper
2.0 Impulse Turbo
Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: pucci] #755976 11/04/06 08:57 AM
lttlbddy Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Project Time!!
Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: lttlbddy] #755977 11/04/06 09:15 AM
Madcat Offline
+1
Jim
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: front brake upgrade for early trucks - swapping over 2G+ parts [Re: pucci] #755978 11/07/06 06:30 AM
HOLLA!!!!!!!!!!11
let me know when you want me to measure motor mounts, engine dimensions, etc. <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6407 MB (Peak: 0.7504 MB) Data Comp: Off Server Time: 2026-06-15 10:41:14 UTC
