anyone beadlock stock alloys (snowflake)? #755979 10/06/06 12:55 AM
CPOM Offline OP
Not really something I have intention of doing any time soon just wondering if anyone has tried it. I know you can buy ring kits, and some come with aluminum inner rings to be TIG'd to the alloy wheel.
CHRIS
98 Amigo, 92 Pup
Re: anyone beadlock stock alloys (snowflake)? [Re: CPOM] #755980 10/06/06 04:21 AM
randii Offline
No reason why not... I have considered it, but not pulled the trigger. I like the snowflakes, but I'm not sure I like 'em THAT much.
Randii
Re: anyone beadlock stock alloys (snowflake)? [Re: CPOM] #755981 10/06/06 01:28 PM
HCMP Offline
Is it really that bad to MIG aluminum?
My readywelder says it will do it but I've never tried. In class we only ever TIG'd for like 2 days (need a lot more practice than that) and I thought it was just because the wire would be a pain to change out of a dozen machines.
Re: anyone beadlock stock alloys (snowflake)? [Re: HCMP] #755982 10/06/06 03:29 PM
Jim_Paget Offline
MIG, with the correct wire and gas is used widely on aluminum in the boat-building industry.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: anyone beadlock stock alloys (snowflake)? [Re: Jim_Paget] #755983 10/06/06 05:51 PM
RobG Offline
as Jim said, no, its not bad, but it is different and requires a very different setup which usually keeps away the average person only needing to weld aluminum very seldom.
the alum. wire is softer and doesn't like to be fed long distances through typical MIG guns w/o birdnesting... which is why a special spool gun is generally required (generally a few hundred bucks and requiring a compatable machine).
for those using a 75/25 shielding gas setup, aluminum requies 100% argon meaning changing out tanks.
alumn doesn't conduct electricity as well meaning its going to require more from your machine (usually requiring the bigger 220v machines).
also, good prep/cleaning work is cricual to remove oxidation that occurs on the alum before welding.
-Rob
Re: anyone beadlock stock alloys (snowflake)? [Re: RobG] #755984 10/06/06 09:36 PM
Z
zKnightWhoSaysNi Offline
aluminum doesn't conduct electricity as well as what, copper? Aluminum conducts electricity quite well. try touching a wire to an aluminum ladder while plugged into an outlet in the garage while you hold the ladder and see how well electricity is conducted through the aluminum!
Remember that older homes may still have some aluminum wiring instead of copper.
'99 Trooper, 912's
'89 Trooper RS, 2.6
Re: anyone beadlock stock alloys (snowflake)? [Re: zKnightWhoSaysNi] #755985 10/06/06 11:59 PM
litnin Offline
I don't think he said it "didn't" conduct electricity,
I believe he said it didn't conduct it "as well"... meaning
compared to other materials, such as steel or copper.
And he is exactly right. Aluminum does not conduct
electricity as well as the other materials...
Just because it was used in houses doesn't mean it does just
as good a job. It was done, because at the time, it was cheap.
In fact, in most all code now, aluminum is illegal to use
in residential wiring because it's too easy to over-heat.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: anyone beadlock stock alloys (snowflake)? [Re: litnin] #755986 10/07/06 03:19 AM
RobG Offline
Yes, since this was a discussion regarding MIG welding... I was comparing welding aluminum vs mild steel, the more common base material (at least in this circle) used with the MIG process.
and while i'm not arguing aluminum will carry a current, it does so much different than other metals... a characteristic important for welding. afterall, the current your welder outputs is very different from carry household current over an aluminum conductor.
-Rob
Re: anyone beadlock stock alloys (snowflake)? [Re: CPOM] #755987 10/08/06 03:53 AM
Triathlete Offline
These would look sweet...
Billy
VEHICROSS.INFO
'99 Vehicross 3"OME lift Torsion bar crank Ball joint flip 31" BFG AT's (everyday)/MTR's (wheel'n) Trooper skids OBA...more to come!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6261 MB (Peak: 0.7311 MB) Data Comp: Off Server Time: 2026-05-27 23:49:52 UTC
