Swap an ABS diff into non ABS axle? #756469 10/09/06 05:21 PM
bigStinger Offline OP
I have a non ABS truck that needs a new rear diff. I found one via car-part, but it says it has ABS on it. Will that be an issue or is it something I can remove?
tks
For Sale or Trade
33" AT Winston Wheelers. Nearly New.
all stock except for 4.88s...
Re: Swap an ABS diff into non ABS axle? [Re: bigStinger] #756470 10/10/06 01:20 AM
Staceman Offline
not an issue at all. You can keep the top piece connected to the diff, and just cut the cable. Got 2 like that in my 4Runner. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Swap an ABS diff into non ABS axle? [Re: Staceman] #756471 10/10/06 05:03 AM
jasonmt Offline
Originally Posted by Chris Geiger
Later V6 3rd members have a hole on top of the diff for the anti-lock brake sensor. When installing this diff in an older truck you don't have a sensor to put in the hole. Some have suggested making a block off plate. Another solution is to use a 3/4", deep cup expansion plug (freeze plug). Napa stocks them, part number 219-3038. Cheap and easy to get. Easy to install: just slide a socket into the cap and tap a few times with a hammer.
Re: Swap an ABS diff into non ABS axle? [Re: jasonmt] #756472 10/10/06 06:47 AM
kewlynx Offline
Now that's whatcha call slick; thanks for posting that one! <img src="/forums/images/graemlins/cheers.gif" alt="" /> Still learnin' my '99....
**ubi apis- ibi salus**
Re: Swap an ABS diff into non ABS axle? [Re: kewlynx] #756473 10/10/06 06:59 AM
jasonmt Offline
Some 94/95 4Runners and all third gens should have the ABS sensors at the axle ends. The freeze/frost plug trick is for the single circuit rear ABS used from 89-95+ that used the ring gear as the "tone ring".
Re: Swap an ABS diff into non ABS axle? [Re: jasonmt] #756474 10/10/06 07:07 AM
kewlynx Offline
Said Runner is a 2.7L plain jane 4x4, so ABS was actually optional (and no ABS light when I put the key to 'on')
Just a little trivia...no ABS on the dog's Runner. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Swap an ABS diff into non ABS axle? [Re: kewlynx] #756475 10/11/06 01:44 AM
jasonmt Offline
Now you have me a little curious Margie as in my limited experience with 3rd generation 4Runners I have never seen one without ABS?
Does your rear axle have the tone rings and recessed axle seal as shown below or is it missing those as well?
Re: Swap an ABS diff into non ABS axle? [Re: jasonmt] #756476 10/11/06 01:52 AM
kewlynx Offline
Jason, to be honest, I've only had the 4R since July, so haven't had to really tear into it, other than getting the truck on a maintenance schedule, given no records. The truck has had only 3 owners (I'm #3; #2 had it for only 2 months)--a real grocery getter.
I can say this, without a teardown:
No ABS light when keyed
No ABS sensor on rear axle
Doing a hard brake from 60 mph does not result in ABS activation
No associated relays, etc are mounted in the engine compartment
I'll try and source for you where I discovered ABS was an option for the 2.7L 4x4, and edit this.
EDIT: 3rd gen info There are a couple other personal sites which have the ABS-optional mentioned; but this is a good writeup overall.
Eighty-eight, yeah, I looked for the ABS components with some help from the FSM, that's one of the reasons I'm fairly sure I don't have ABS. BTW that hard stop from 60 mph I managed in less than 200 feet; I didn't baby it. <img src="/forums/images/graemlins/notooth.gif" alt="" /> Picture an 800 pound moose launching out of the willows....
Re: Swap an ABS diff into non ABS axle? [Re: kewlynx] #756477 10/11/06 02:25 AM
eightyeight Offline
just take a look to see if the brake lines run from the m/c to a hydraulic control unit (HCU).
easiest guaranteed way to tell if its got abs.
and if the newer 4runners have wheel speed sensors on the axles, then they prob dont have em at the diff. just a thought, i dont own one.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: Swap an ABS diff into non ABS axle? [Re: eightyeight] #756478 10/16/06 08:24 PM
Picked up front and rear diffs for a grand total of $350 from an awesome junkyard in Charlottesville called Harry Wrights
Question - front diff is ADD, but my truck is manual hubs. I read the tech article about defeating ADD and realize that that is probably the path of least resistance. However, I would prefer to actually implement the ADD. Anybody ever took a manual hub truck and make it ADD? I am thinking that I would simply lock the front hubs and then I would have to run some sort of vacuum to the diff and control through a switch somehow... just that simple, right <img src="/forums/images/graemlins/lol.gif" alt="" /> ?
Thanks much!
For Sale or Trade
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6373 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-06-16 14:03:49 UTC
