maickey thompson baja claws #756719 10/10/06 07:02 PM
ok, im looking at changing my tires, currently bfg mt's. i have been offered radial baja claws for a good price, ca anybody tell me what they are like on the road?? how noisy are they compared to the bfg's??
thanks
brian
Re: maickey thompson baja claws #756720 10/14/06 10:36 AM
the baja claws are just about as loud as super swamper tsl's on the road, but they also grip a lot better on trails than the bfg.
Re: maickey thompson baja claws #756721 10/29/06 06:56 PM
88SuperTrooper Offline
Mickey Thompsons wear really hard, which means more mileage. The BFG KO's are alot softer tread compound better traction on wet surface but do not wear for very long on the street. Its a Toss up. Mickey's ARE much heavier than the KO's. Your Best Bet is to have them Siped. In Case you dont know what that is: Its where you take a Tire and CUT Slices in the tread, ONLY do the Center OF the TREAD. This will make them last longer, Wear better because they run cooler, and YOUR traction Goes thru the Roof because the tire in opening up for more tread on the ground. I work in a Tire shop and have done one set of each, Mickey's and the KO's, and the Mickey's lasted longer and the Traction between the 2 was about the same after the Siping. NOISE wise the Mickeys were VERY LOUD and the KO's were better about it. Since BFG is owned my MICHELIN they also rode better. I would go witht eh Mickey's if the price is right they last longer. Although if you like the Spin your tires DONT do the Siping you will rip the lugs right off same with gravel roads ( off roading is ok, Ie: Slow speed, tire runs cooler ) as well try to avoid that all together. For the Price of Siping it's well worth it, Your Doing your self a Favor by making the Life of the tire extend. and your traction.
89'Isuzu Trooper LS 5 spd 2.6L
31" Big O X/T's
15x8 Eagle 058's
K&N Filter w/ Air Box Mod
2.25" DynoMax SuperTurbo
PolyUrathane/Indy4X Bushings
Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: maickey thompson baja claws [Re: 88SuperTrooper] #756722 10/30/06 01:29 AM
ducktrooper Offline
why not look at the new MT Baja MTZ mud tires or Dick Cepek Mud Country. Both are siped and designed for on and off road.
'99 Trooper, ARBs, 4.77s, ARB bullbar, Warn M8000 w/Amsteel, OME 912s w/2.5" spacers, Rancho 9000xs, K&N/Magnaflow, 33" Kumho MT's, Aisins, boulder bars, Indy 4X brake lines, diff drop, Flexalite
Re: maickey thompson baja claws [Re: ducktrooper] #756723 10/30/06 03:41 PM
Nice, I forgot about those, NOW those are awsome. The MTZ is great, they kick it in the mud, I would still add siping to them anyway, even if they have it some from the factory already, I would defintily add more. We put some on one of our guys 2500HD Duramax and he LOVED them, Siped them and they did even better, Down Side they are still just as loud as the Baja Claws though.
31" Big O X/T's
15x8 Eagle 058's
Re: maickey thompson baja claws [Re: 88SuperTrooper] #756724 11/06/06 09:43 AM
52degrees Offline
You keep talking about BFG KOs. Do you mean KMs? I thought the KOs were all terrains and the KMs (which is what I have) are mud terrain.
KG6VNX
Re: maickey thompson baja claws [Re: 52degrees] #756725 11/06/06 03:45 PM
Ahh, may bad I meant KM's Sorry, thats BFG's way to throw me off, all the letter and KM, KO, TA KO's. sorry
31" Big O X/T's
15x8 Eagle 058's
Re: maickey thompson baja claws [Re: 88SuperTrooper] #756726 11/07/06 12:56 AM
52degrees Offline
It's all good. I just wanted to make sure we were comparing apples to apples here.
I've been seriously sonsidering Claws for my next tires after I wear out my KMs. I'm really interested in knowing what kind of wear folks are getting from them.
KG6VNX
Re: maickey thompson baja claws [Re: 52degrees] #756727 11/08/06 01:28 AM
eightyeight Offline
from what ive seen, baja claws burn pretty quick. similar to tsl's, not quite so bad though. certainly wear a LOT quicker than bfg's (either a/ts or m/ts). they hook up though. and they definitly look cool, which is all that matters anyway right? <img src="/forums/images/graemlins/smile.gif" alt="" />
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: maickey thompson baja claws [Re: eightyeight] #756728 11/19/06 07:43 PM
One word...Geolandars. Great tire at a great price. Tire Rack
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6292 MB (Peak: 0.7322 MB) Data Comp: Off Server Time: 2026-05-26 00:58:42 UTC
