Re: sourcing engine mounts [Re: yankneck696] #756986 10/12/06 11:47 AM
Y
yankneck696 Offline OP
OK, I tried Mrautoparts.com again under V6 Montero & they have the mounts. Nothing under Raider. They are the same part, right?
Thanks for all the help, guys...
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: sourcing engine mounts [Re: yankneck696] #756987 10/12/06 12:11 PM
FrankR Offline
Same/same....... AFAIK, the only difference is badging. I've found it better to always use the Montero lookup for parts... for the 3.0L '89 model year.
Frank
Re: sourcing engine mounts [Re: FrankR] #756988 10/12/06 03:10 PM
sparkem Offline
Yeah, same part.
Re: sourcing engine mounts [Re: sparkem] #756989 10/12/06 09:19 PM
Happy Birthday MI_Mitsu Offline
Just a word of caution - 3 weeks ago I bought a set from Mr. Auto Parts also based on recommendations here.
What I got were 2 "DEA" brand boxes, but what was inside was anything but. Both motor mounts were made by different companies - one T&N (molded into the rubber) - the other who knows. Both had different black paint finishes, and they both had the original Mitsu # on them, but the T&N mount had the locator nipple 180 degrees reversed. The "good" no-name brand had the locator nipple on the right side, but it was off by 1/8 to 3/16" - making both unusable. They were shipped back and received by Mr Auto Parts last week Friday.
A week later I have no refund or email telling me what the problem was and if a repalcement batch is being sent.
Mr Auto Parts has a good reputation and he might simply have been given a bad batch - but I got 2 mixed up parts, neither of which worked or came from the same manufacturer.
89 Montero LS 3.0L/Auto
90 MightyMax 2.4L/Man
Parted/gone - parts available!
89 Montero LS 3.0L/Auto [Blue/Blue] (2 of 2)
89 Conquest SHP
88 Conquest SHP
87 Dodge Raider 2.6L/Auto
91 Montero RS 3.0L/Auto
Others: 37 Lincoln
Re: sourcing engine mounts [Re: yankneck696] #756990 10/12/06 10:22 PM
BobShaw Offline
Don't forget to try NAPA. I am continually surprised with what they can get for Mitsu's. Or call RCSR 800 695 4700 for used. Besides Raider, ask for Montero parts.
Re: sourcing engine mounts [Re: BobShaw] #756991 10/13/06 11:47 AM
Y
I did try NAPA, along with each & every parts house in the area. I work in a salvage yard & would rather not use used parts like that. I continually have to refund money after I tell customers that want expendables (water pumps, belts, engine mounts, carbs)"Mine is as old as yours". I have alot of time and money (in the junkyard world) into this swap, already & want to finish it off right. When fully broken in, I am going to add the 3.8 GM supercharger using the old school caravan/voyager intake manifold & need good mounts.
That said, I might just rework the old ones & use urethane bushings to make them stronger. I do happen to have alot of urethane bushings in a box that I have pulled from Fords.
Thanks...
Ed
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6203 MB (Peak: 0.6904 MB) Data Comp: Off Server Time: 2026-11-19 05:28:10 UTC
