87 mitsubishi montero / cylinder head torque specs. #757078 10/11/06 09:27 PM
mkgrizz Offline OP
Anybody have the cylinder head torque specs. for the Montero 4 cyl. 2.6L., specifically the caps that hold the overhead cam in place. Appreciate any info. !!
Re: 87 mitsubishi montero / cylinder head torque specs. [Re: mkgrizz] #757079 10/11/06 11:13 PM
Angel Carlo Offline
head bolts are cold engine...65-72 ft.lbs
" " hot engine...73-79 ft.lbs
Camshaft bearing cap bolts...14.15ft.lbs
Hope this helps.
1987 Dodge Raider rebuilt Quest block bored .040 over put together, and installed by Shelby. 5spd, '87 stock turbo, Intercooled, 2.5" exhaust. MPI with hard pipes, FIP Pro-4, MSextra MS1
Re: 87 mitsubishi montero / cylinder head torque specs. [Re: Angel Carlo] #757080 10/12/06 03:26 AM
FrankR Offline
Cylinder head bolt torque specs were revised for several engines. Both the 2.6L and the 3.0L head bolt torque specs are 80 lb-ft..... hot or cold.
Frank
Re: 87 mitsubishi montero / cylinder head torque specs. [Re: Angel Carlo] #757081 10/12/06 12:57 PM
mkgrizz Offline OP
hey thanks!!!!!! To all who gave info...having too much fun.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5992 MB (Peak: 0.6543 MB) Data Comp: Off Server Time: 2026-06-21 09:34:20 UTC
