Page 2 of 3 1 2 3
Re: T-case problems,in low/hi-range at same time [Re: Bansil] #757286 10/16/06 05:39 PM
Bansil Offline OP
Micheal,you where right <img src="/forums/images/graemlins/pfft.gif" alt="" />,I just didn't know it was supposed to freewheel.
It did turn afterall <img src="/forums/images/graemlins/lol.gif" alt="" />
What you said..... now makes perfect since <img src="/forums/images/graemlins/cheers.gif" alt="" />
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: T-case problems,in low/hi-range at same time [Re: Bansil] #757287 10/17/06 05:40 PM
Bansil Offline OP
Update:
Pressed Bearing out of lo gear.........lo gear is trashed do to rust and corrosion.
Called jerry,he's gonna try to hook me up.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: T-case problems,in low/hi-range at same time [Re: Bansil] #757288 10/17/06 06:17 PM
Bigpoppax2 Offline
I have about three of those gears Doug, just let me know if you need it. It's yours. They are just paperweights in my garage.
Joe
Re: T-case problems,in low/hi-range at same time [Re: Bigpoppax2] #757289 10/17/06 10:06 PM
strawmyers Offline
Isuzu Moderator
I have my OEM gearset still laying around as well... in case all three of Joe's don't pan out. <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer
Re: T-case problems,in low/hi-range at same time [Re: strawmyers] #757290 10/17/06 11:54 PM
mlclark Offline
Isuzu Moderator
I've got one too, if you want one from the Northwest. (Purported to be a much better gear than the mid-west).
Don't forget to match to the proper year/case style. I think, in general, the fixed yoke cases have a different number of dog teeth for the synchro.
Michael
Re: T-case problems,in low/hi-range at same time [Re: mlclark] #757291 10/18/06 01:56 PM
Bigpoppax2 Offline
I already told him to throw the brass rings and the dog teeth away. I know I don't need to shift from 4 high to 4 low while moving or vice versa. It makes the install much easier IMHO. Alot of cases cmae from the factory that way, no synchros at all. The 94 Rodeo case that's in my truck now has no synchros at all. It shifts just as good or better than the one I had in my 88 Trooper that had synchros.
Joe
Re: T-case problems,in low/hi-range at same time [Re: Bansil] #757292 10/18/06 05:40 PM
Bansil Offline OP
Thanks guys
I will check on my slipyoke case and count the teeth etc.
and post for future tech.
Syncro teeth count should be the same since each tooth matches with one on the gear right?And since terralows are terra lows,except for the shift rails right?
SO all gear driven cases should have the same lo gear right?
I saw you called Joe,left phone at garage and battery was dead last night.
Two that Joe has are auto cases w/fixed yoke right?and one was a 5spd (marks) did it have a slip yoke?
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: T-case problems,in low/hi-range at same time [Re: Bansil] #757293 10/18/06 06:22 PM
RobG Offline
I can save you the trouble... <img src="/forums/images/graemlins/smile.gif" alt="" />
-Rob
Re: T-case problems,in low/hi-range at same time [Re: Bansil] #757294 10/19/06 05:32 PM
Bansil Offline OP
Thanks Rob
Good tech.
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: T-case problems,in low/hi-range at same time [Re: Bansil] #757295 10/23/06 05:40 PM
Bansil Offline OP
Ok guys,I need a 42 tooth (counting missing teeth)
Jerry sent me one but it is 48 tooth.....so the search continues.
BAnsil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6445 MB (Peak: 0.7534 MB) Data Comp: Off Server Time: 2026-06-17 11:42:12 UTC
