Page 3 of 3 1 2 3
Re: T-case problems,in low/hi-range at same time [Re: Bansil] #757296 10/23/06 06:16 PM
ehess Offline
I'll take a look at mine when I get home. '95 Troop manual flanged d-shaft if that helps to narrow it down.
-Erik
1995 Trooper SOHC, 255/85R16 Dunlop Mud Rovers, OME 912, 2" Daystar coil spacer, torsion bar crank
Tera-Low in the T-case and 5.38's Rear LSD
Re: T-case problems,in low/hi-range at same time [Re: ehess] #757297 10/24/06 12:28 AM
strawmyers Offline
Isuzu Moderator
Mine is 48 teeth as well. <img src="/forums/images/graemlins/confused.gif" alt="" />
[edit]BTW, mine is 48 teeth but slip-yolk. I know '93 (the year of my Amigo) is the year they switched from slip-yolk to fixed-yolk in the Amigos. Apparently I have an unusual cross between the two (slip-yolk, but with fixed-yolk # of teeth). I would say I'm shocked, but its Isuzu <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer
Re: T-case problems,in low/hi-range at same time [Re: strawmyers] #757298 10/24/06 02:19 AM
mlclark Offline
Isuzu Moderator
I've got one. PM me.
Michael
Re: T-case problems,in low/hi-range at same time [Re: mlclark] #757299 10/24/06 02:48 AM
W
Wareagle Offline
Doug: I've got the one from my tera install. No slip yoke.
Re: T-case problems,in low/hi-range at same time [Re: Wareagle] #757300 10/24/06 01:06 PM
Bigpoppax2 Offline
I must have cleaned out some of my "parts I'll never need again" pile. I have two gears but both are 48 toothers.
Joe
Re: T-case problems,in low/hi-range at same time [Re: Bansil] #757301 10/24/06 05:34 PM
Bansil Offline OP
Thanks Mark,Joe I sent a Pm to Micheal.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6162 MB (Peak: 0.7023 MB) Data Comp: Off Server Time: 2026-06-12 04:16:36 UTC
